help needed a couple of swap problems
Old Jan 22, 2008 | 06:04 AM
djsire's Avatar
Default help needed a couple of swap problems
i have an h22a1 in a 93 civic.
the guys who put it it did some funny booltleg business with the tranny mount.
there is a bolt welded to the mounting point, then the mount ocnnects to the tranny.
it was fine like that for a year but now its starting to tear. (welds where the bolt is)
I want to fix this issue. and probably get new mounts and replace the the factory mounting point which was removed.
thanks for your help
is this hard to do? how much do you think it will run?
Old Jan 22, 2008 | 06:06 AM
chad's Avatar
Moderator
Default Re: help needed a couple of swap problems (djsire)
without any pictures it is hard to tell....your best bet is to take it to a reputable shop to get an estimate.
Old Jan 22, 2008 | 06:29 AM
djsire's Avatar
Default Re: help needed a couple of swap problems (chad)
if somone can post a pic of a bare engine bay i could explain better
Old Jan 22, 2008 | 11:29 AM
Bakeoff's Avatar
If the factory mount was removed and this jacky **** was welded in, it would really depend on how they welded the mount in. Whatever the case may be, the engine may need to come out.
Take it to a shop, get a quote, and see what they say.
I think you just learned the less to not buy a car that someone else modded unless you have the resources to rip it apart and do it right yourself.
dth0ng69
13
Jul 10, 2011 12:16 PM
B00M3R
Feb 17, 2010 02:02 AM
tylerdurden
Jul 6, 2003 03:59 PM
hydroflip
Feb 26, 2003 01:37 PM
FUP23
14
Aug 3, 2002 12:09 PM
