Help H22 wiring
Old Jan 31, 2002 | 12:01 PM
Accord1999's Avatar
New User
Default Help H22 wiring
I need help wiring up an H22 USDM to a 97 civic hatch. Can anyone send me a diagram on the wire connection from H22 to the civic driver side engine bay harness and at the passenger side kick panel harness. Email: nisnisan@optotech.com
I have the Helms manual for both but I want to do the easy way by asking people who had done this. I will be using a 96 integra ECU. Thank you.
Old Jan 31, 2002 | 12:55 PM
WICKED2's Avatar
New User
Default Re: Help H22 wiring (Accord1999)
what year is the engine ?
if the car is obd2 and the engine is obd1 or obd2 as long as you have a jumper u'l be fine u can use obd2 ecu or for better power and mod. get a jumper and use obd1ecu
Old Jan 31, 2002 | 04:08 PM
Accord1999's Avatar
New User
Default Re: Help H22 wiring (WICKEDII)
The H22 engine is 97 and I want to stay to OBD2 and start the motor before I switch to OBD1.
Old Feb 14, 2002 | 05:59 AM
WICKED2's Avatar
New User
then its should be pluginplay
your ecu will fit but some car are diff. i've swap h22 on civic and accord obd1 and obd2 i always recommend to stay on obd1 its alot better.
but yeah you have an obd2 car and obd2 engine it should be plugin play
b17itr
Sep 7, 2009 09:43 AM
granturismonut2
Mar 31, 2008 09:54 AM
Prudz_lude
Oct 18, 2007 12:13 PM
Sille98
Sep 24, 2005 01:00 PM
Ri5e
Mar 4, 2004 09:04 PM
