HELP!!!! Car wont start!?!?!?!!?!?
Old Jan 15, 2003 | 03:21 PM
vtec69's Avatar
Default HELP!!!! Car wont start!?!?!?!!?!?
I just changed the seals behind the cam gears cause they were leaking. I had to remove the starter and loosen the alt belt to do this cause i also had to take the crank pulley off so i could set the timing properly. I didnt take the cams out to do this and didnt remove anything with wires beside the battery.
I went to start it up and it sounds like the battery is dead but its showing a charge on my charger. It wont turn over at all and the lights and the radio work but it sounds like the battery is dead
Can anyone help????
TIA
-Brian
Old Jan 15, 2003 | 07:38 PM
hybridsol's Avatar
Default Re: HELP!!!! Car wont start!?!?!?!!?!? (vtec69)
Did you connect the little black plug to the starter? it's the ground. It's easy to miss- it's black, small and a spade type connector. I've missed it several times
Sean
Old Jan 15, 2003 | 10:43 PM
AtomiK_EK's Avatar
Yep, on my car, the battery was fully charged, but the car wouldn't start. It turned out the ground wire was loose. Check all the ground wires from the battery.
Old Jan 16, 2003 | 07:08 AM
vtec69's Avatar
Default Re: HELP!!!! Car wont start!?!?!?!!?!? (AtomiK_EK)
It turned out that the battery was very dry so i added some distilled water and charged it for 2 hours and when i went to start it it would only turn over if i gave it gas.
So i messed with the intake and throttle and got it to start
thanks for your help everyone
also BTW:
Is the t-belt suppose to wobble a little along the side by the exhaust manifold while the throttle is open?
Old Jan 16, 2003 | 07:30 AM
Soled Out's Avatar
How much is it wobbling?
Old Jan 16, 2003 | 07:35 AM
vtec69's Avatar
Default Re: HELP!!!! Car wont start!?!?!?!!?!? (Gray EG on Jack Stands)
id say about an inch
-Brian
Old Jan 17, 2003 | 03:30 PM
Dave P.'s Avatar
that side is suppose to have the most tension on it. When you string up the t-belt, you stick it on the cams the work your way around counterclockwise from the cams...
once you have it all lined up, then you tighten the tensioner....
Dave 92 VTEC
http://lude92.tripod.com/VTECLude
silentkid
Mar 3, 2010 11:59 AM
egtony
May 18, 2009 09:58 AM
vtec69
Jan 16, 2003 07:09 AM
vtec69
Jan 16, 2003 07:07 AM
