H2B CRV
Old May 6, 2009 | 03:54 PM
newby_j's Avatar
Needs More Cowbell
Default H2B CRV
Well I know that some of you know about this by now so I am going to go ahead and make it public knowledge.
As most of you know I have a 1998 CRV. RTAWD 5 spd
On April 5, the timing belt went. The previous owner said that it had been done, but apparently not.
About a year ago I bought a QSD H2b kit to use on my coupe but this seems like way more fun!!
On April 6, I picked up a JDM H22 for a great deal that needed some love. It had had the valve cover off of it when the previous owner was cutting wood, So I decided that it was time for a freshening.
I don't have pics of the motor at this point because I forgot to take pics before it went to the machine shop.
The motor is basically going to be stock.
Fresh rings and ACL bearings.
Lots of new Oem seals and gaskets.
Balance shafts eliminated.
I made the plate.
Cometic Headgasket
ACT Flywheel
Cleaned up the distributor and added a new oem cap and rotor
Cleaned up the thermostat housing
I have not found anyone that makes mounts for the CRV so I purchased a set of Innovative EK mounts that I am going to modify
Also a Golden Eagle cam seal and some NGK's
Removed the old motor
The plans for now are to make it run and drive and maybe build a higher HP motor for it next year.
I have a few tricks up my sleeve with this one, so stay tuned!
Old May 6, 2009 | 07:00 PM
high_revs's Avatar
Default Re: H2b crv
i always wanted to do this sure will be fun to drive
Old May 6, 2009 | 07:19 PM
sirEGhatch's Avatar
Default Re: H2b crv
awesome!
Old May 6, 2009 | 08:11 PM
iwanttokillgod's Avatar
Default Re: H2b crv
this looks cool im gonna watch
Old May 6, 2009 | 09:11 PM
soxle's Avatar
Default Re: H2b crv
cool idea! i gonna do the same combo but in a EG hatch.
Old May 6, 2009 | 10:04 PM
kikih22's Avatar
Default Re: H2b crv
hey cool!! something different...wish u luck buddy
Old May 6, 2009 | 10:27 PM
lunatics209's Avatar
Default Re: H2b crv
cool build. i wouldn't want to run into that crv on the street.
Old May 7, 2009 | 12:12 AM
Pippen_001's Avatar
Default Re: H2b crv
What did you use to clean the distributor and thermostat housing? It's gonna look great if you keep it all that clean. Good Luck!
Old May 7, 2009 | 12:13 AM
sp00ledbseries's Avatar
Default Re: H2b crv
In for awesomeness
Old May 7, 2009 | 04:18 AM
redzcstandardhatch's Avatar
something different
Default Re: H2b crv
so rad. rediculously rad.
Old May 7, 2009 | 04:31 AM
SiR_Chris's Avatar
Default Re: H2b crv
Awesome.
Did you need to hone the cylinders when replacing the rings? It's a different process for the H22 isn't it?
Old May 7, 2009 | 05:27 AM
newby_j's Avatar
Needs More Cowbell
Default Re: H2b crv
Thanks for the comments everyone!
The dizzy and the t-stat housing were just wire wheeled. The block and head are super clean thanks to the machine shop
I want to do a tuck on this like I did to my civic, but I am really anxious to drive it.
I found the recommended honing procedure and gave it to the machine shop. they are putting rings and bearings in it and I am putting the rest of it back together.
Old May 7, 2009 | 06:56 AM
hondaZvic's Avatar
Default Re: H2b crv
freaking awesome man!!!!!!!
Old May 7, 2009 | 06:38 PM
88ED8's Avatar
Default Re: H2b crv
Originally Posted by high_revs
i always wanted to do this Sure will be fun to drive
x2
Old May 7, 2009 | 06:45 PM
2fast4u831's Avatar
I'm really 2slow
Default Re: H2b crv
will keep an eye out on this build. good stuff man.
Old May 7, 2009 | 07:06 PM
pgpbubble's Avatar
Default Re: H2b crv
sorry to say manl but I doubt this will work without some modding.
The starter mounts on the front of the RT4wd trans vs the rear, your going to have to cut the plate out and drill mounting holes somehow.
Old May 8, 2009 | 10:21 AM
Japankid's Avatar
Default Re: H2b crv
nice r u going to hit up the track ?
Old May 8, 2009 | 10:32 AM
88ED8's Avatar
Default Re: H2b crv
That's a small problem...
Old May 8, 2009 | 12:27 PM
raidacaipo's Avatar
Default Re: H2b crv
me wanna see!
Old May 8, 2009 | 01:24 PM
something different
Default Re: H2b crv
looks like he might need to chop the plate a bit to make the starter fit.
Old May 8, 2009 | 01:54 PM
patotas's Avatar
Default Re: H2b crv
looks like its gonna be fun...
Old May 8, 2009 | 01:57 PM
thevtecnician's Avatar
Default Re: H2b crv
As someone said before the different starte location is a small issue. Maybe a 15 minute fix. Anyone this is very interesting and I can't wait to see some 60 foot times
Old May 8, 2009 | 07:03 PM
Garage 808 Hatch's Avatar
Default Re: H2b crv
Cool idea, ive always wanted one of these
Old May 10, 2009 | 03:30 AM
sicc22's Avatar
Default Re: H2b crv
subscribed
Old May 14, 2009 | 05:31 AM
qwrty's Avatar
Default Re: H2b crv
holy cow!!
thats sick!!
good luck..
