h23 or b16
Old Feb 22, 2003 | 03:07 AM
ImportFreek1991's Avatar
Default h23 or b16
k i can get an h23 with tranny and ecu with only 120,000 k. for $1500 canadian dollars
or a b16a2 complete for $3600 canadian dollars
i know i need to buy a few more things for the h23 to swap in a 94 civic coupe.
but ...for the price dif on the motors. whats my best way to go
i plan on runnin a bit of boost
Old Feb 22, 2003 | 01:34 PM
Default Re: h23 or b16 (ImportFreek1991)
bump
Old Feb 22, 2003 | 10:22 PM
-=-'s Avatar
If I was you ill go with the h23, its alot more powerful then the weak b16, plus you dont have to rev all the way to 8000 to get power, the h23 i believe goes to 6700? (both has 160 hp, in this case its better to get there quicker instead of revin all the way to 8000) anywho, my friend owns both a h23 prelude and a 00 civic si, the h23 is much better, and if you want to be quicker on the freeway, the h23 tranny is better, whenever he shifts to 4th in hes prelude it starts to walk away from the civic si, hope this helped.
Old Feb 23, 2003 | 08:35 AM
Greg L's Avatar
deffinentley go with the H23, it's got 160 Hp and 160 torque where as the b16 only has 160/111. Also, turbo h23 is insane. You'll need a set of mounts, i reccomend HAsport, and you'll need to get axles (2g integra) and an older accord mid shaft thingy.
Old Mar 19, 2003 | 04:11 PM
BAZ's Avatar
BAZ
Default Re: h23 or b16 (Greg L)
If you don't plan on doing anything but straight line, go with the H23
EF's, EG's, and EK's all have mad understeer with an H-series motor.
Old Mar 19, 2003 | 05:21 PM
JdmCIVIC853's Avatar
Default Re: h23 or b16 (BAZ)
DUde i have an h22 eg and it doesn't have understeer at all anyone who thinks it does is gay...its just like any bseries....weiner
[Modified by JdmCIVIC853, 6:22 PM 3/19/2003]
Old Mar 19, 2003 | 08:47 PM
mitsuman's Avatar
when was the last time you drove one?
Old Mar 19, 2003 | 09:02 PM
@irborne's Avatar
dude; have you really driven in one b4? so just passing urban legend
Old Mar 20, 2003 | 09:37 AM
BAZ's Avatar
BAZ
Default Re: h23 or b16 (JdmCIVIC853)
OK, first of all you are obviously not mature enough to have a normal discussion without resorting to name calling. Secondly, a couple of my buddies run h22's in their EG's and EF's and said that it was not worth it and they have mad understeer. The only reason I even responded in this forum was because I was considering an H-series swap in my crx, and decided against it because of this. I considered my options and bought a prelude. (where the H-series belongs)
Dont be so ignorant, and consider the FACTS, a H-series civic will NOT perform as well around a corner than a B-series, case closed. Don't even bother responding to this post if you don't really want opinions, If an H-series is working out well for you, than good, just don't resort to name calling. It makes you look stupid and ignorant. I'm done.
Oh, and yes I have driven one. (actually two)
[Modified by BAZ, 6:39 PM 3/20/2003]
Old Mar 20, 2003 | 09:43 AM
Suprdave's Avatar
Internet Hype...
KraeZi
Mar 13, 2006 01:27 PM
hondabigblock
Feb 22, 2006 12:34 PM
