Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Hybrid / Engine Swaps (https://honda-tech.com/forums/hybrid-engine-swaps-18/)
-   -   h22a ej and vibration problem. (https://honda-tech.com/forums/hybrid-engine-swaps-18/h22a-ej-vibration-problem-1456554/)
GeeGee Dec 7, 2005 12:17 PM
Car: 93 ej, stock height, stock suspension
Engine: Usdm H22a4
I searched:
8 topics in recent content
16 topics in achieved content
....and I read through all the relevant ones without any result.
My vibration problem is rather simple. It not caused by axles binding since it vibrate just as bad when I gave it gas in neutral or let off the gas while the car still moving. The vibration is not as bad at idle, but as soon as I give it a little gas, the whole car rattle loudly, it seems like the vibration is there through all range of rpm.
I bought these mounts from ebay as a compulsive buy and that was totally dumb of me.
https://pic1.picturetrail.com/VOL115.../121146322.jpg
I’m leaning toward the quality of the mount as the cause of the vibration. But before I spend more money replacing the mounts, I want to rule out all the other facts.
1. I’m running stock, which is 97+, rear bracket, even though it fit but it took some creativity do so….would a 92-96 rear bracket solve this problem?
2. Would the absent of balancing shaft cause this problem? I haven’t check since I haven’t got a lightest idea where it would be.
3. If you can think of anything else please feel free to chime in.
IHateJDM Dec 7, 2005 01:36 PM
Re: h22a ej and vibration problem. (Lycanthrope)
I doubt your mounts are causing it since the better aftermarket mounts that use polyurethane bushings transfer most of the motor vibration to the chassis too. If you don't have your balance shafts, or the belt is cut, that could be it. The balance shafts are in the bottom of the motor on either side of the crank (look at the driver's side of the motor by the crank pully).
GeeGee Dec 7, 2005 01:47 PM
thanks, i'll check it you to day. If anybody need a vid to see the vibration, that could be arranged as well.
GeeGee Dec 7, 2005 05:12 PM
Re: (Lycanthrope)
would the rear bracket cause this problem?
BiGbLoCkHoNdA05 Dec 7, 2005 06:18 PM
i removed my balance shafts and i dont have this problem. and i`m using the same mounts as u...but i am using a 93 rear bracket..doubt that is ur problem
lodo1 Dec 7, 2005 10:02 PM
Re: (Lycanthrope)
make sure your mounts are all tightened up? especially the rear one on the crossmember
GeeGee Dec 7, 2005 10:25 PM
Re: (BiGbLoCkHoNdA05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BiGbLoCkHoNdA05 &raquo;</TD></TR><TR><TD CLASS="quote">i removed my balance shafts and i dont have this problem. and i`m using the same mounts as u...but i am using a 93 rear bracket..doubt that is ur problem</TD></TR></TABLE>
so basically we have the same set up except for the rear bracket, I"ll look into that since that's seem to be the only factor.
