H22A Axles in DC4
Old May 27, 2004 | 07:53 AM
RedK's Avatar
Default H22A Axles in DC4
Hi, I have a DC4 Integra and am looking to swap in a H22A motor. I searched around in the forum for the info and see I need 2nd Integra (90-93) axles with preferrable a passenger side prelude innerjoint and Accord midshaft.
But, i've also seen in other forums and places that the 1st gen Integra axles are a much better fit in the same configuration. Now, for those who have done the swap, which axles should I pick ? I'm not going to get some custom made ones like hasport sells, just some rebuilds, so I really need to know.
Thanks!
Old May 28, 2004 | 08:31 AM
RedK's Avatar
Default Re: H22A Axles in DC4 (RedK)
Anyone ?
Old May 28, 2004 | 12:04 PM
Turbogixxer's Avatar
How low is the car?
90-93 teg axles are about 1/4" longer than 89 teg axles. The lower your car is, the more bind you will see.
It is better to use the prelude mid-shaft with prelude inner CV cups on both sides (They have more depth).
Old May 28, 2004 | 12:47 PM
jeff652's Avatar
Use:
1989 Integra Axles
Prelude Inner joint on BOTH sides
H22 Mid shaft
This combo is the best OEM axle solution for the H22 swaps.
HTH
Jeff
Old May 29, 2004 | 11:36 AM
RedK's Avatar
Default Re: H22A Axles in DC4 (jeff652)
Good, thanks guys! the car is not to low (1.75" drop on front) but with your comments and the other ones I got i'll go with the 1st gen axles.
mrfury67
Feb 11, 2009 11:53 AM
ballermc5
Jul 18, 2005 05:33 PM
JdmCIVIC853
Sep 12, 2003 01:20 PM
95civic-vtec
Apr 26, 2003 08:01 PM
SCsol
Jun 29, 2002 06:15 AM
