h22 wiring ek
i am wiring up my harness right now..i have a 94 h22a and its going into a 97 dx civic..i have a ex harness on the motor right now...everything matches up pretty good , just have to extend here and there but anyways, what have you guys done on your distrubutor plugs???? i assume i cut the lude plugs off and then wire them into the harness..right?? also the injector resistor box looks fun as hell...anyone have any diagrams on the injector resistor?? thanks for any info ..trying to get this done asap...thanks
imma try and help u as much as i can.. this is what i just did on my car and its running pretty good.
cut the distributor plugs? which distributor are u using? i just re wired the distributor straight to the ecu... as for the resistor box.. my motor is a 2000 .. and i come to find out that 2000's injectors have the resistors built into them.. so i dont have to use a resistor box. u might wanna try getting some injectors from a 2000 lude. but if u use the resistor box i know there are some diagrams in the archives if ur willing to search for it.. i saw them about a month ago. good luck
LivinDreamsEK9
Aug 17, 2007 05:38 PM
