H22 swap...PLEASE HELP!!!
ok...i have a 01' H22a4...i am swapping it into a 93Cx hatch...i got all the parts...i'm now doing the wiring...i used a harness from a D15B(Dx) and i'm using all the prelude plugs and splincing the wires together by colors...i've got everything wired except the external coil and distributor...i'm totally stuck on what colors go with what colors on the ext. coil and dist. can anyone help with the color codes...
again i have a OBD2 dist. and external coil...the motor is a 01' H22 and i'm wiring a 92-95 civic harness to it...does anyone have the colors for both harnesses...or know where i can get em online? PLEASE HELP!!!
i dident mess wit the wiring on mine cuz i had to convert my obd1 B18b moter to obd2 , all i did iz buy a obd2 B18b distributer , if you what you can look for a obd 1 distributer for a H22 and it should plug right up , worked for me
anyone know about wiring the obd2 dist. and external coil to the dx harness??? i really need help with that...i don't think i can find a obd1 dist. today...
take the internals out of the civic dist. put them in side the lude distput it back together drill asmall hole in the cap run the + & - wire from the coil out of the hole then hook them to your coil. this worked for me.
I think you need an ODB II computer to have a ODB II distributor.. Just get an ODB I distibutor and make your life easier. It will bolt up properly and work well with p13.. As far as wires all you need is knock, vtec pressure switch, and vtec solenoid wires to the ECU.. Some people get an EGR code some people dont..
civiclude92...that **** acually works? sounds like if you drill a hole in your dist. cap..i won't get good connection..same as having a cracked cap
i'm gonna be using a 95 Accord F22 dist. i talked to poison and he said it will work...said they are all the same...its obd1 too...so if anyone has any other info on this...lemme know!
