H22 swap to integra
Hey I have a problem I swaped a H22 into my integra and I just got it back together and every time I drive it and it gets up to a decent speed even like 40 mph it kinda shakes and if I turn right it does the same thing but worse something starts to vibrate or something but only if I turn normaly if im going straight It dosent do it! If anyone has every encountered this problem please let me know what I can do to fix it!!!!
Thanks
Thanks
What's your axles combination? And how low did you drop your car? And does it vibrate during accelaration? Get back on this. Oh yeah you're from Clearfield? Hey I'm from Logan. Maybe if I cant get it solved online. Maybe we can meetup and I can check it out to see what your problem is
Hey yeah its drop pretty low it vibrates alittle bit when accelerateing too really a pain Im going to try to lift the car with some coilovers to see if it takes some stress away I think the angle is whats causeing but never had this problem have you ever had this problem? Im trying to get it finished so I have a everyday driver. everything else seems to fit good I have the enjo motor mounts and I call enjo they said it could be how low my car is! drop me a line and let me know what you think it is so I can try it! thanks alot
Oh yeah the combination is 90-93 integra axles and a 93 accord half shaft!
IF your car is really low, it will cause your axles to bind because of the angle that the lowed car puts the spindles. Try a 88-89 integra axles, that are shorter and replace the inner CV joints with the prelude joints.
Yeah, I'm using the same axle combo as yours. But mine did vibrate during accleration. But it was because my driver side axle was bad from being so low. So I replaced it. And my car is slam about 3". But it stop when I raise it up an inch. So try raising it up and let us know. Any pics of your ride? Cant wait til RMR opens up to see what my time is.
