H22 swap help
92-96 Shifter metal
97-01 Shifter plastic
Both do the same job as long as you mount them correctly. Mounting holes appear to be different, but that doesn't matter as you will tailor your own. Also it's note worthy to make the final adjustments after the engine is mounted and 100% bolted down. You can also use the Accord shifter as well. Hope this helps you out.
So the cables are the same the only difference is the mounting holes and the one is plastic correct I will be making my own mounting holes that's a given pretty much seen as how the civic isn't a cable shift
I'm going to lean on that they are slightly different lengths. I will say this though, get the cables for the shifter you are using. If you need the cables and the shifter, why not get them together?
Maddox
Apr 17, 2005 08:32 AM
