H22 redline
Old Dec 8, 2002 | 06:10 PM
h22 civ's Avatar
Default H22 redline
I am having a spoon chip installed in the JDM P13. I was wondering how high I can safely rev the engine. The redline is 7200, removed to 8500.
Old Dec 8, 2002 | 07:15 PM
Jonathan_ED3's Avatar
Default Re: H22 redline (h22 civ)
7200
It's not a b16.
Getting a chip on a stock motor in no way changes how high you can rev it 'safely'
Old Dec 8, 2002 | 08:30 PM
Alstare's Avatar
7500 is safe... but your gonna stop making power around 6800-7000 anyway.
Also the JDM p13 doesn't have a rev limiter only a speed limiter<127mph>, or if it does have a rev limiter it's higher then 8k cause i haven't ever hit it but i have hit my 8k limit on my MSD a few times by accident
[Modified by Alstare, 12:33 AM 12/9/2002]
Old Dec 9, 2002 | 08:11 PM
H22EK's Avatar
Default Re: H22 redline (Alstare)
remember that above 7500 the oil pump in the h2 is week and you will starve the motor of oil if you hold it above 7500 for long witha stock pump
Old Dec 9, 2002 | 09:49 PM
hondaZvic's Avatar
Default Re: H22 redline (H22EK)
i have a 2000 usdm h22a4. with a jdm obd1 p13. i have rev'd my car all the way to 8400 then it cuts off. and my speedo cuts out @120mph
Old Dec 10, 2002 | 03:48 PM
h22 civ's Avatar
Default Re: H22 redline (hondaZvic)
I was hoping valve springs and retainers would let me rev higher, but I need an oil pump too. Didn't know they sold larger ones or do they. Just seen oil coolers.
Old Dec 11, 2002 | 05:53 PM
H22EK's Avatar
i forgot what company sells tham but they do make new pumps to solve this problem
Old Dec 11, 2002 | 05:58 PM
poison's Avatar
good advise. I better not rev my motor higher than 7500 RPM anymore then
Old Dec 11, 2002 | 06:15 PM
BeerBaron105's Avatar
Default Re: H22 redline (poison)
are u guys sure its that, my friend has an ex-v eg sedan (everything except d16z6) and he has an h22a and he shifts at 8000 on the tach, maybe the tach reading is different or something but thats what he shifts at
Old Dec 11, 2002 | 06:53 PM
fmfkid250's Avatar
Default Re: H22 redline (BeerBaron105)
I have this same problem i have a 94 4door gsr with an h22a1 and i used that comp... the fuel cut off seems to be about 7700 on my tach? speed 120this sucks ...i would like to know when to shift also? what round 7200? thanks
Old Dec 11, 2002 | 08:04 PM
poison's Avatar
I have the spoon chip as well. and I shifted at 8000 rpm's.
Old Dec 12, 2002 | 05:44 AM
MPower332TI's Avatar
I shift my jdm H22 at 7400 rpm (with the aid of a auto meter shift light). You gotta remember that the stock tach is off my at least 200 rpm. It usually reads 200 rpm more than what youre acutally at. I dont really watch my tach all that much but rather look at the vafc. Take a look in anyones car with ethier and aftermarket tach or a vafc and compare that to what the factory tach reads. Anyways i wouldnt rev the h22 past 7500 if its stock.
Old Dec 12, 2002 | 05:56 AM
satan_srv's Avatar
Default Re: H22 redline (jDmDxTuRd)
redline is 7400. Fuel cut is at 7700
Does someone have a link to these upgraded oil pumps?
Old Dec 12, 2002 | 06:08 AM
cccya's Avatar
well i have a JDM P13 and it cuts out @ 7500RPM and has a speed limter @ around 120MPH.
so i would say some JDm P13's do have a revlimter.
but i still agree that anything over 7500-7800 is just wasting your time. unless of course you have the cams and fuel to give you power over 7200RPM
[Modified by cccya, 3:09 PM 12/12/2002]
.Hatches.
Engine Management and Tuning
Mar 28, 2009 01:10 PM
H22LUDE808
Jan 25, 2009 11:35 AM
JDM00SI
Oct 22, 2004 12:58 PM
H22aAccord
Aug 30, 2004 06:34 AM
Mikey3000
Jun 26, 2002 08:22 PM
