h22 mounts
Old Dec 12, 2004 | 08:18 PM
weak16teg's Avatar
Default h22 mounts
which h22 mounts give more ground clearnce hcp or hasport?
Old Dec 12, 2004 | 10:23 PM
fastwanabe's Avatar
Default Re: h22 mounts (weak16teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weak16teg &raquo;</TD></TR><TR><TD CLASS="quote">which h22 mounts give more ground clearance hcp or hasport?</TD></TR></TABLE>clearance of what? ground clearance? rad clearance? axle clearance? hood clearance? firewall clearance? be more specific please.
Old Dec 13, 2004 | 12:48 AM
O3DigitalBath's Avatar
Default Re: h22 mounts (fastwanabe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastwanabe &raquo;</TD></TR><TR><TD CLASS="quote">clearance of what? ground clearance? rad clearance? axle clearance? hood clearance? firewall clearance? be more specific please.</TD></TR></TABLE>
read, he said ground clearance
Old Dec 13, 2004 | 06:00 AM
Adam.'s Avatar
Default Re: h22 mounts (O3DigitalBath)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O3DigitalBath &raquo;</TD></TR><TR><TD CLASS="quote">
read, he said ground clearance</TD></TR></TABLE>
Pointless post. And besides he probably meant, measuring from the ground to what point on the car.
They have nearly the same with +/- .5" However, the type of suspension and header you have will be the biggest factor. When my d was in I had easily a 5-6 finger gap. After the h went in I had barely 4. Not only that, but if you are measuring from your header down then it will entirely depend on the design of the header.
Most of all, if this is what you are basing your decision on for the mounts, you are wasting your time. Hasport has the name, HCP has the value. The choice is yours to make.
Old Dec 13, 2004 | 07:59 AM
fastwanabe's Avatar
read, he said ground clearance</TD></TR></TABLE>oops my bad
Old Dec 13, 2004 | 10:48 AM
weak16teg's Avatar
just wanted to know on the lowest point of the motor wether it be the header or oil pan. it'll most likely be the header (an-r). i didn't think there would be much of a ground clearance differance between the two just wanted to be sure
turbogsr18
Mar 19, 2008 08:18 AM
Rcp
Northern California (Sales)
10
Jul 9, 2007 07:20 PM
BatLude
Jun 5, 2006 07:49 PM
JBk24crx
Nov 23, 2004 02:01 PM
civic702
Apr 30, 2003 08:44 PM
