H22-into-ef mounts
Old Feb 26, 2005 | 06:29 PM
thevtecnician's Avatar
Default H22-into-ef mounts
I am planning on putting my jdm h22 into my ef hatch and i need mounts. i want some hasport mounts for it. i heard bad **** about place racing, so i don't want them. i am willing to pay good amount for them, since i can't find them anywhere else, and they are no longer produced. i am in the 916 and prefer to get them from here. holla bakk at me 916-568-1142. also, i am looking for skunk2 stage 2 cams, and anything for the head(aftermarket wise)
Old Feb 26, 2005 | 06:43 PM
locash's Avatar
Default Re: H22-into-ef mounts (thevtecnician)
Hasport has never released an H-Series mount kit for the EF chassis. Rumor is, the kit may be available in a few months.. Cross your fingers and keep waiting..
Old Feb 26, 2005 | 07:15 PM
Default Re: H22-into-ef mounts (locash)
that's funny, people are just stupid i guess. what about enjo
Old Feb 28, 2005 | 08:00 PM
VTECVillain's Avatar
There aren't any H series EF mount kits on the market yet. People that have done the swap have made custom mounts or modded other mounts to work. I would seriously wait for the HASport kit to come out, should be soon.
Old Feb 28, 2005 | 09:09 PM
slrh22hatch's Avatar
your from sac, just go to warren at midnight performance or north valley performance in stockton. both those shops have done the h22 swap in a ef
Old Feb 28, 2005 | 09:17 PM
Default Re: H22-into-ef mounts (slrh22hatch)
https://honda-tech.com/zero...age=3
pics of my car swap was done by north valley performance
Old Mar 1, 2005 | 05:22 PM
Default Re: H22-into-ef mounts (VTECVillain)
i already talked to warren, he wants $1000 to make the mounts. i usually **** wit capitol high performance, because he is closer to me. and he said the same price
Old Mar 1, 2005 | 08:46 PM
H22HondaCRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thevtecnician &raquo;</TD></TR><TR><TD CLASS="quote">I am planning on putting my jdm h22 into my ef hatch and i need mounts. i want some hasport mounts for it. i heard bad **** about place racing, so i don't want them. i am willing to pay good amount for them, since i can't find them anywhere else, and they are no longer produced. i am in the 916 and prefer to get them from here. holla bakk at me 916-568-1142. also, i am looking for skunk2 stage 2 cams, and anything for the head(aftermarket wise) </TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1159288 this might help you out
here is the info that i have if you need it
HONDA EF 88-91 H-SERIES SWAP INFORMTION
(IF YOU UES THE H-SERIES TRANSMISSION) (Axles use)
if you the h-series tansmission you have to use the 1989 Integra axles whit the drivers side innter cv swapped out whit the Prelude one to make ues of the Prelude I.S. only no the drivers side
( ADAPTER PLATE FOR THE H-SERIES TO B-SERIES)
if you can find one or make one.
you can use b-series mount's on the transmission
(Wiring ) you can use the hasport converion guide from O.B.D.0 to O.B.D.1 you can use the stock CRX si hariess.most of theplugs work on the h22 whit the exception of some of the sensors which were all rewired to the newer O.B.D.1 plugs .the ecu was all hardwired . so im tell you that the hardest part of this swap is going to be the WIRING.at lest four me i suck at wiring
(ECU)
you can use p13,p28
( FRONT CROSS MEMBER)
you have to get a front cross member you can get a place racing one or jim fab will work as well.
( MOTOR MOUNT'S)
you have to make comtostom mount's
(CLUTCH CABLE )
you have to make a bracket and use the stock ef clutch cable
(comtostom cuting work that has to be done)
you have cut the frame near the crank pulley and the tranny side .
you have to cut the left headlight bracket to give the alternator clearance
and run a smaller belt .
(STRUT FORKS)
you have to swap the strut forks from side to side to give the axles more clearance .
it makes about 1/2 "of more room
(shiftter assembly and cabless)
same as doing it in an eg/ek
(the driver side tie bar)
the front lower cross member to the lower control arm
you just heat it up and bend it
good luck i am want to do this swap to this is why i have all this info
Old Mar 12, 2005 | 09:10 PM
12pt3secH22ef's Avatar
slrh22hatch u going to CMI? i saw u run at test and tune i dont think it was impressive.
Old Mar 12, 2005 | 09:11 PM
it also looks like u got the same setup as me......
Old Mar 14, 2005 | 01:11 PM
Default Re: H22-into-ef mounts (12pt3secH22ef)
Really!!!! Are u someone special that I should give a **** what u think. 12.5 @ 107 with header, intake, exhaust is impressive to me.
Old Mar 14, 2005 | 06:49 PM
twelve3H22ef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slrh22hatch &raquo;</TD></TR><TR><TD CLASS="quote">Really!!!! Are u someone special that I should give a **** what u think. 12.5 @ 107 with header, intake, exhaust is impressive to me. </TD></TR></TABLE>intake headers exhaust 12.5@107 dam u hella sorry u must be a sorry *** driver i did it with stock headers and catback pipings from muffertech...u a liar, u running hotshot headers and no exhaust.....i hope u do come to CMI so i can laugh at u and show u a better time slip....im not saying im good but i know im better than you.[
Old Mar 14, 2005 | 07:33 PM
NXLude's Avatar
well......my dad can beat up your dad!
Old Mar 15, 2005 | 06:42 PM
Default Re: (NXLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NXLude &raquo;</TD></TR><TR><TD CLASS="quote">well......my dad can beat up your dad!</TD></TR></TABLE>
that it some funny ****
miked123
Sep 10, 2013 04:08 PM
89hatcher
Nov 4, 2007 05:19 AM
mymeatb18"
Apr 24, 2006 12:16 PM
brian g
73
Feb 22, 2005 07:11 PM
