h22 dist and engine madness!!!
Old Mar 9, 2003 | 03:51 PM
2trix's Avatar
Default h22 dist and engine madness!!!
breif story for ya:
got an obd1 h22.
got an obd2 ecu.
dist on my car looks exactly like the h22's only diff is h22 is one plug and mine (obd2 civic dx) has one plug, same # of wires.
will the dist that i have for the h22 work with my obd2 ecu?
same question with my starter? obd1 stater. will it work with my obd2 ecu?
everything should work fine right? any insight on this would be awsome thank you!
Old Mar 9, 2003 | 04:05 PM
poison's Avatar
Default Re: h22 dist and engine madness!!! (2trix)
yes it'll work. You just need the OBD2 plug from your stock dist, and convert the h22 distributor to obd2 by cutting off the plug, and matching the wires on the OBD2 plug. then you're done
eliteek
Apr 25, 2011 01:20 PM
Ri5e
Mar 4, 2004 09:04 PM
