H22 Cooling Lines
Old Aug 13, 2003 | 09:26 PM
DropSquadCivic's Avatar
Default H22 Cooling Lines
to the guys who have h22s in the civs, what hoses did you guys use for the ones the come out of the head, the little ones?
pics would be much appreciated also!
Modified by DropSquadCivic at 12:45 AM 8/14/2003
Old Aug 14, 2003 | 01:23 AM
2.2L EH2's Avatar
Default Re: H22 Cooling Lines (DropSquadCivic)
bring your old upper radator hose to your local auto shop tell them you want it to look the same as your old upper radiator from sohc motor. but you want bigger in diameter and longer. thats what i did. it cost about 7 bucks. and for the longer one that connects to the bottom of the radiator. i just used the old hose that came with the h22 swap. it wasn't cut or anything. HMO
Old Aug 14, 2003 | 04:50 AM
VTECVillain's Avatar
1992 Integra LS (B18A1) Upper Radiator Hose
1994 Del Sol VTEC (B16A3) Lower Radiator Hose
You will need to C-Clamp them to an OEM radiator since the neck is smaller.
Old Aug 14, 2003 | 07:16 AM
Default Re: H22 Cooling Lines (VTECVillain)
my bad y'all i meant the little hoses, i think they are my heater hoses or something, theres an opening on the side left side of my head, then there's an opening on intake mani side...... what about those?
hybridevul
Jun 16, 2005 07:03 AM
slim9300
May 1, 2004 09:48 AM
