Guys I need help badly..
Hi,to all my family of honda-tech.
I need help you guys out here.I got my honda civic 88dx hb swap to Integra B18A1 DOHC ZC non-vtec have a black valve cover with the bolts on that sides. Are running smooth a couple months. I drive everyday to work.
I just wonder the following day my car won't start just getting a crank only. I tried to find the main problem for about 3 weeks but still no improvement at all.I got a Big headache for my honda.this is faulty as of my observe.
I use ECU PM6 is getting throwing code 15, fault Ignition output signal. right?
I replaced the dizzy right away because the black/yellow wire for igniter there is no Voltage.basically i use dizzy TD23U? Is this correct for my MOTOR?
please correct me i need to know what dizzy to be use for my MOTOR is it OBD0 right?
and then when i atempt to start second times?the main relay won't click and ENGINE CHECK Light on..tried to start then Motor got Crank.
this is headache for me.new dizzy and SparPlug then i got same code throwing 15?
anybody there to help me this problem, I appriciated.
Honda Tech member,God Bless you Always.
"the main relay won't click and ENGINE CHECK Light on..tried to start then Motor got Crank"
The main relay and ECU share a common ground located on the thermostat housing.
If it is disconnected, you can crank all day, but that's all you get + a solid CEL.
Someone did a dual port fuel injection to multi point injection swap on your car at one point.
Ive done a few on prior cars and i ran into your same situation it ended up being disconnected.
I think it was pin number c1 at the ecu and it connects to the blue/green wire at the distributor.
Guys thanks a lot all of you for the reply and i am really sorry for my delay response. Basically I'm too busy for a couple days. now i will do today guys this some information about my car problems.i will let you know later regarding of my car if it is working and get more improvement.once again i appreciated you guys to help me to figure out to ran back my car.God bless you all.
Mikzize
Jan 31, 2014 07:00 AM
sircrx615
Mar 25, 2011 08:01 AM
