GSR dash in a CX . . .
How the hell do I make this work? I have seen it done but mine is being an ***. Also - the grey wiring connector from the GSR dash/instrument cluster is 4 pins larger than the CX. Do I use the CX harness and then move the wires to work in the GSR cluster? Does the steering column brace (big-*** pipe) need to come out?
Let me add that I am only concerned with the instrument cluster working. Everything else has been gutted out from under the dash already.
SEARCH!!!!
haha had to be an *** to Mr.Dick.
https://honda-tech.com/zerothread?id=269340
https://honda-tech.com/zerothread?id=265792
https://honda-tech.com/zerothread?id=170977
https://honda-tech.com/zerothread?id=165468
haha had to be an *** to Mr.Dick.https://honda-tech.com/zerothread?id=269340
yeah i didnt read the links...i just typed in GSR dash in the search engine for Civic forum and posted the links... I don't know what's involved because I havent done it. Sorry I couldnt be of more help bro.
i think Migs has dont it before, maybe you should ask him, dustin did it to his crx but it might be a little different for a cx. after you're done maybe you could make a step by step on how to do the swap, i also want to do this.
oh ya, liam821 did it also, maybe you could search for post created by him.
good luck
good luck
b20vtecturbe
Dec 2, 2009 09:48 AM
eg686
May 8, 2005 11:11 AM
TurboEG6
Apr 20, 2004 12:29 PM
