Gauage Cluster
Old Jul 23, 2002 | 07:03 AM
KENLUDE97's Avatar
Default Gauage Cluster
Ok what guage cluster will fit in a 96 Civic Hatch? It does not have a Tach and that will be needed inorder to the car to its fullest potential. Will a 99-00 Si cluster fitor a ITR fit? The EX Tach does come with a Tach correct.
What all will fit in there?
Thank-x
Ken
Old Jul 23, 2002 | 07:15 AM
EK22Tim's Avatar
Default Re: Gauage Cluster (KENLUDE97)
Another thing..
If I were to install a Civic Si, Ex, etc. cluster in my CX Hatchback, will the speedo be off? Isn't the gearing for this inside the tranny itself? Can I fix? Thanks guys!
Old Jul 24, 2002 | 12:45 AM
AllMotorHB's Avatar
The Si and EX are the easiest because they plug in without having to rewire anything. I think the SI cluster looks ALOT better than the EX. GSR and Type R clusters will also work, but you need to do some rewiring.
Old Jul 25, 2002 | 06:27 AM
EK22Tim's Avatar
Default Re: Gauage Cluster (AllMotorHB)
Ok. Does the speedo read accurately with an H22 swap? Where exactly is that determined? in the ECU? I can't seem to find this one.. Is everything going to read as it should, whether i go with the EX or Si cluster??
Old Jul 25, 2002 | 08:22 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Default Re: Gauage Cluster (mitsuman90)
WHat about if your speedometer needle works sometimes and other times it doesn't. I really don't want to shell out the money for a brand new speedometer.
Project-Ek9
Sep 21, 2008 10:00 AM
97civicsedan
Jul 9, 2005 07:46 PM
JSPECEX
Mar 23, 2003 07:53 PM
b16b hatch
Jan 9, 2002 08:21 PM
