Fuel Line Question
Old Mar 5, 2003 | 03:19 PM
timmo's Avatar
Default Fuel Line, is it the same in 99'-00' Si and ITR???
Does anyone know if the fuel line from the filter to the fuel rail is the same in a 99'-00' Si (Si-R in Canada) and a ITR?
Did a search already.
[Modified by PwrByHonda, 7:21 PM 3/5/2003]
[Modified by PwrByHonda, 7:22 PM 3/5/2003]
Old Mar 5, 2003 | 07:13 PM
VTECVillain's Avatar
Default Re: Fuel Line, is it the same in 99'-00' Si and ITR??? (PwrByHonda)
They are slightly different in the way they bend and mount on the fuel filter. I am almost certain that the Si is slightly shorter too. If you are doing a swap, you should be able to use either one though.
Old Mar 5, 2003 | 08:54 PM
timmo's Avatar
Default Re: Fuel Line, is it the same in 99'-00' Si and ITR??? (VTECVillain)
Thanks for the info
What would you say about the bend/mounting position at the fuel rail, would that be the same?
wicked_b16eg
10
Feb 1, 2008 02:36 PM
t3to4e
Mar 4, 2004 06:58 AM
migs
Jan 29, 2003 01:35 PM
b18c-93
Dec 15, 2002 09:06 PM
