F2D Mounts for Ek
I have been reading around for awhile now and I cant seem to find out which mounts do I use for this swap. I think I use the d-series t bracket and upper trans mount. What about the driver side mount?
you can use your stock mounts for the rear and passenger side, or aftermarket d series mounts i.e. hasport, avid, ect. you would have to custom make a mount for the driver side or use a stock or aftermarket mount like hasport and make a custom bracket that bolts to the block like what qsd has with their plate and mount kit. You might also call up bisimoto and see if he already supplies a mount kit with his adapterplate kit. I have an ef and all hasport mounts are supplied when I bought my plate from him
hi, i have the same question too.
if i have some engine mount like hasports for d series engines.
in the driver side i should use or make my own bracket? or there is an aftermarket alternative out there?
thanks
Rod
thanks
Rod
teamvirus
Northern California (Sales)
Nov 8, 2006 08:33 PM
BigBlockCRX
10
Dec 30, 2001 07:42 PM
