F22 ECU on H22
Old Jun 8, 2003 | 08:16 AM
dominate9's Avatar
Default F22 ECU on H22
Picture an Accord with an H22 swap. Would the car run at all with a F22 ECU? What do you think would happen?
Old Jun 8, 2003 | 10:26 AM
eg6ajk's Avatar
Default Re: F22 ECU on H22 (dominate9)
also depending on the type of motor and F22 ecu? many variants will respond differently,but most of them will run the motor .
don't expect performance
Old Jun 8, 2003 | 10:40 AM
dominate9's Avatar
Both the ECU and motor are VTEC. So a ECU for aSOHC car with an external coil can be used on a DOHC motor with an internal coil? I won't mess my engine up?
Old Jun 8, 2003 | 10:43 AM
Ryu's Avatar
Ryu
I had to temporarily use the F22 ecu on my H22a Accord while i was waiting for a P13 to be replaced...
My original F22B was a non vtec, running it on the H22A was fine, i wouldnt recommend thrashing your car around until you get a P13 or another ecu that has the correct fuel maps for your DOHC engine... But then again you should be safe as your rev limiter is set at a meezly 6500
Old Jun 8, 2003 | 10:45 AM
dominate9's Avatar
How long did u use the ECU? What were the noticeable differences?
Old Jun 8, 2003 | 11:05 AM
Ryu's Avatar
Ryu
Default Re: (dominate9)
I had it in my car for about 3 weeks, after i got the P13 it was a hell of a lot different!
With a F22 your car feels real sluggish, your revs take ages to build up and overall it just feels like all that $$ you spent on the conversion did jack all cause it feels like a SOHC engine
Old Jun 8, 2003 | 01:27 PM
Jason kiDD's Avatar
I used my 91 Accord ECU for like 6 months without any problems. Matter of fact the car pulled like a monster and I was whiping Stock LS b-series cars all day. However not having Vtec can leave a withdrawl symptoms..
No problems with idle or sluggishness either..
Old Jun 8, 2003 | 04:02 PM
dominate9's Avatar
Default Re: (Ryu)
Did you have to do some wiring since the OBD I H22s are internal coils and the F22s are external coil? How did u get the F22 ECU hooked up?
Old Jun 8, 2003 | 04:49 PM
Jason kiDD's Avatar
Just plug in the ECU and go. Assuming your car is already ODB I.
acracer2008
Nov 7, 2010 07:51 PM
londonsupra
Jun 17, 2006 11:52 PM
tr0n9h
Sep 13, 2005 06:20 AM
Godspeed94
Apr 7, 2005 12:54 PM
abeaujuin
Jul 23, 2004 12:14 PM
