F20B to be installed this month...........
Old Apr 1, 2005 | 08:30 PM
F20B EG6's Avatar
Default F20B to be installed this month...........
im putting an F20B in my 93 SI HB this month. it looks to be quite the fun project.
ill keep my progress and pics on here as they come.
wish me luck.
-abe
Old Apr 1, 2005 | 08:38 PM
BlueIntegraBoy's Avatar
Default Re: F20B to be installed this month........... (bucknut)
Ok, good luck
Old Apr 1, 2005 | 09:01 PM
dohcVTECeg2's Avatar
good luck
Old Apr 1, 2005 | 10:30 PM
EeeJayEight's Avatar
Default Re: F20B to be installed this month........... (dohcVTECeg2)
havent heard of anyone doing this... probs for being individual
Old Apr 2, 2005 | 02:28 AM
Kidnkorner's Avatar
An F20B Swap should be the same as an H22A.
Modified by Huggy Bear at 9:34 AM 4/2/2005
Old Apr 2, 2005 | 03:39 AM
MrMacros's Avatar
sir-t engine
Old Apr 3, 2005 | 12:25 AM
F20B EG6's Avatar
Default Re: (MrMacros)
thanks guys. yea not so much a common swap. and yes, quite similar to an h22 swap.
itll be fun
Old Apr 3, 2005 | 11:02 AM
Do_Ster's Avatar
apologies for the newb question but the f-series engine uses an iron block correct? if so, turbo that bitch! if not poo on me
Old Apr 3, 2005 | 07:40 PM
F20B EG6's Avatar
Default Re: (_OEM_)
what?!
Old Apr 3, 2005 | 10:53 PM
Do_Ster's Avatar
Default Re: (bucknut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bucknut &raquo;</TD></TR><TR><TD CLASS="quote">what?! </TD></TR></TABLE>
lol judging by your reply i must be way off. could of sworn i read/heard it somewhere. gotta stop hanging out with 240 guys
Old Apr 5, 2005 | 01:39 AM
Kidnkorner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bucknut &raquo;</TD></TR><TR><TD CLASS="quote">thanks guys. yea not so much a common swap. and yes, quite similar to an h22 swap.
itll be fun</TD></TR></TABLE>
from what i have read the F20B is a destroked H22, has the same mounts and everything that bolts to a H22 will bolt to the F20B
Old Apr 5, 2005 | 07:22 AM
Loki12's Avatar
had a buddy of mine do this same swap in a 97 civic..and i had 2 say i was quite impressed..i liked it alot infact..
Old Apr 5, 2005 | 07:39 AM
AutoXer's Avatar
Default Re: (CRX Junkie)
So where is the tech in this post?
Success
» Post reported
The post was successfully reported to the moderator. Click here to return to the topic.
Old Apr 5, 2005 | 07:52 AM
Happyman's Avatar
Default Re: (EX_AutoXer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX_AutoXer &raquo;</TD></TR><TR><TD CLASS="quote">So where is the tech in this post?
Success
» Post reported
Wow are you a kiss *** or just a tool? The kid was just making a post so that as hes doing the swap he'll post up his progress. I'm guessing your a wannabe mod.
Old Apr 5, 2005 | 08:44 AM
blurboEK's Avatar
Default Re: (_OEM_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _OEM_ &raquo;</TD></TR><TR><TD CLASS="quote">apologies for the newb question but the f-series engine uses an iron block correct? if so, turbo that bitch! if not poo on me</TD></TR></TABLE>
F20B has an aluminum block but it does have iron sleeves like its F-series brethren.
Old Apr 5, 2005 | 08:45 AM
AutoXer's Avatar
Default Re: (Happyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Happyman &raquo;</TD></TR><TR><TD CLASS="quote">
Wow are you a kiss *** or just a tool? The kid was just making a post so that as hes doing the swap he'll post up his progress. I'm guessing your a wannabe mod.</TD></TR></TABLE>
Yes, I'm a huge tool; one who is tired of non-tech threads. Great, he's doing a swap. I'm happy for him, and I'm sure he's excited; that doesn't mean he should make a thread about it.
Old Apr 5, 2005 | 09:20 AM
Happyman's Avatar
There have been lots of threads over the years people made to keep progress of their projects....
Old Apr 20, 2005 | 01:51 PM
F20B EG6's Avatar
wow. that took awhile.
heres a couple pics of my mizotor for yall.
its coming along. im gathering parts right now.
Old Apr 20, 2005 | 04:29 PM
Sex Cells's Avatar
looks hot, ive thought about doing this same swap...
dont pay attention to the asshat
EDIT: how much did the motor cost you, and where did you get it?
Old Apr 20, 2005 | 10:56 PM
cpforyou's Avatar
Default Re: (Eugenics)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eugenics &raquo;</TD></TR><TR><TD CLASS="quote">looks hot, ive thought about doing this same swap...
EDIT: how much did the motor cost you, and where did you get it?</TD></TR></TABLE>
I think it's a very good swap for those who don't want to spend money in building a block. The F20B has a good R/S ratio, sports 11.0:1 Compression, and comes with ported intake manifold! All you have to do is add a good intake, header, exhaust, along with a good set of cams, and you're pretty much at 200WHP.
Old Apr 21, 2005 | 07:32 AM
Sam1am26's Avatar
Default Re: (cpforyou)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cpforyou &raquo;</TD></TR><TR><TD CLASS="quote">
All you have to do is add a good intake, header, exhaust, along with a good set of cams, and you're pretty much at 200WHP.</TD></TR></TABLE>
Most definitely... I wanna do an f20b build sometime soon...
Old Apr 21, 2005 | 09:17 AM
cpforyou's Avatar
Default Re: (Sam1am26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam1am26 &raquo;</TD></TR><TR><TD CLASS="quote">
Most definitely... I wanna do an f20b build sometime soon...</TD></TR></TABLE>
Not only that, the stroke of an F20B crank is shorter than the B20 and LS Cranks as well, and you guys know how high those guys rev those things up to.
Old Apr 21, 2005 | 01:36 PM
F20B EG6's Avatar
"how much did the motor cost you, and where did you get it?"
$2000 for the motor. $400 for shipping.
http://www.jdmsource.ca/honda/index.html &lt;&lt; good guys.
Old Apr 21, 2005 | 03:35 PM
dc2dragster's Avatar
From: eastside of the beach, westside of the coast, Long Beach, CA, usa
just got done with mine a 2 weeks ago, get the hasport kit and itll make life easier for u
Old May 2, 2005 | 12:46 PM
machine4321's Avatar
just got mine in my accord this wekend ..cant wait for he rest of the parts to get there
