F20B in Ek wiring help
Old Dec 31, 2008 | 06:41 AM
tunerraceteam's Avatar
Default F20B in Ek wiring help
I have a 96 civic ex, i just ordered my f20b, i had an h22a1 in there last year, but im a little confused about wiring. I have a new ek harness and my motor comes with the harness, but i need help with the iab wiring. Also i plan on running my chipped p28, thats gonna be tuned with crome. So i need to know what has to be changed so i can run my p28.
Old Dec 31, 2008 | 08:03 AM
F20B-CX's Avatar
Default Re: F20B in Ek wiring help
Your run of the mill P28 doesn't have control over IABs, so your choices are either use an RPM-based window switch ($30-$130), get rid of the IABs ($0) or get a Skunk2 or EuroR manifold. IIRC, Xenocron can add bypass control to P28s for a fee..check his website.
Old Dec 31, 2008 | 08:36 AM
so what if i decide to order a f20b manual ecu, then dp i just get an f20b ecu pinout and a 96 civic ex pinout and just run iab wire, and pin it to the pinout on the f20b ecu???
Old Dec 31, 2008 | 12:42 PM
F20B-CX's Avatar
You could; then you wouldn't need to modify the intake manifold.
Old Jan 1, 2009 | 10:43 AM
is there anyway to run my p28 so i can tune it???
Old Jan 1, 2009 | 11:27 AM
F20B-CX's Avatar
Use an OBD2 to OBD1 jumper harness..pretty easy. Don't tune it yourself unless you know what you're doing.
SoupEk
Sep 8, 2014 02:52 PM
NOFX
14
Apr 26, 2013 06:26 AM
Hoffy
Aug 29, 2005 11:44 AM
streetlvlhatch
Dec 26, 2003 12:59 PM
tour de france turbo
Sep 21, 2002 07:28 PM
