F20B eg axle problem
I have been searching through the forums some to find out what the best axle set up was. ive heard using DA integra axles on both sides but with an 90-93 accord half shaft and inner joint. We had a 3rd gen integra axle in and it blew by the wheel on the passenger side. We figured out the 3rd gen integra axle is suppossed to be 1/2 inch longer than the 90-93 teg but when we went to advanced they had the same part number axle for both generation integras. First my question is what is the best axle set up for the car (eg coupe with f20b) and I am confused on what the inner joint is? if you guys can help it would be really appreciated
90-93 Acura Integra Driver Side with Accord 90-93 F midshaft
90-93 Acura Integra passenger side with Accord Inner Joint put on it without it will not clip into trans and will slide in and out when turning eventually causing carnage
If 90-93 Integra axles are too long in fact 88-89 Acura Integra are 1/2" Shorter
Thats what has happened to both my friends f20b eg and h22 ek coupe. The part we are stuck on the most is the inner joint, may sound like a noob q but what do you mean by that excatly? could you post a pic of one
ShagPower
Feb 10, 2007 07:09 AM
h22ame
Mar 3, 2004 05:00 PM
shiithook
May 28, 2002 12:02 PM
