exhaust?
I have an jdm obd1 gsr swap in my 94 civic cx hatchback and don't know what exhaust to get beacuse the piping on the gsr is 2 1/2.. I was thinking about going 2 1/2 or even 2 3/4 custom piping all the way with an type one titanumin muffler. (can be found at http://www.aj-racing.com)
My friends think i should do the piping then got with the universal muffler of skunk 2, or hks hiper, dunk, or even apex'i n1.
Also what piping size would be best?
Also should get an cat. converter?
Any suggestion would help me alot.
thanx
thanx
first piping on the GSR is about 2" and not more then that (ITR uses about 2 1/4 piping)
for GSR 60-65mm (2 1/4 =57mm) or about 2.5" is more then sufficient for most applications, anything larger might/will hurt low end power as there will not be enough gas velocity.
T1R muffler or complete exhaust is good buy but so are many other systems.
if you care about emissions or have emission testing in the states then yes get a high flow cat (this will depend on the header you use).
typerlover
Oct 29, 2001 10:05 AM
