Euro / JDM ITR B18C + Gearbox on a 95 B16A2 Civic
Well, to cut a long story short, i blew my EG9's B16A2 engine (no one knows why, it was all stock).
The solution was to buy a new engine. I bought a B18C with gearbox from a trashed ITR. No Alternator, Distributor, Starter and ThrotleBody. Once the motor is not yet in the car, i'm in the process of putting up some stuff i had here for the B16A2. I'm talking of a JUN3 cams with JUN valvesprings and retainers, and a SPOON 2 layer headgasket (i thing raises the compression by 0.2 or 0.3). With the 2 motors side by side in the floor. I started to find the differences. Here is what i found: 1 - The engine harness is different, DC2 OBD2 vs EG9 OBD1 DUHHHHHH 2 - B18C have a little sensor right above the oil filter that B16 doesn't. I think is the Knock sensor 3 - the plugs in the injectors, alternator, distributor are different 4 - The B16A2 Vtec solenoid have 1 connector (green) more than the B18C, wich i think is the Oil Pressure switch. Conclusions: Once i need to use my alternator, distributor, starter, i think i better use the B16 engine harness. This makes me changing the injectors plugs and the green vtec plug would be out of use and problably give me a ECU error. I will use my P30 ECU wich already have a ITR with JUN3 program on it the questions: 1 - it's better to use the B16A2 vtec solenoid or use a bypyss for the green plug ?? 2 - using the ITR program on the P30, do i still need to plug the green plug?? 3 - will the alternator, distributor work?? I'm not asking about fitting (no problem, already in place), i'm talking about voltages and power specs. I would appreciate some more info you may find relevant for this to work PS - USDM ITR engine have a vtec solenoid like my B16A2 one, with the green plug. thanks, Nuno |
Re: Euro / JDM ITR B18C + Gearbox on a 95 B16A2 Civic (UnhuZ)
and i forgot https://honda-tech.com/forums/images...s/emhammer.gif https://honda-tech.com/forums/images...s/emhammer.gif https://honda-tech.com/forums/images...s/emhammer.gif
in my EG9 i already have the Euro ITR cluster working for about 6 months... only a few things are not working: 1 - The low fuel light; 2 - The open doors light, only the trunk light (EG only have a single sensor); 3 - SRS lights don't work (My EG don't have air-bags) 4 - The ABS light is working "backwards". It's on when it should be off, and it's off when should be on. https://honda-tech.com/forums/images...es/emsmile.gif https://honda-tech.com/forums/images...es/emsmile.gif https://honda-tech.com/forums/images...es/emsmile.gif cya, Nuno |
Bump !!!!
Well, the car is up and running..... thanks for nothing https://honda-tech.com/forums/images...s/emthdown.gif https://honda-tech.com/forums/images...s/emthdown.gif https://honda-tech.com/forums/images...s/emthdown.gif
