engine swap question
Old Jan 6, 2004 | 05:19 PM
sbacchus's Avatar
Default engine swap question
hey all,
i have a 94 civic EX with a dead engine, i'd like to get it running again as cheaply as possible. the factory engine is the D16Z6 and i know the D15B is considered a direct swap. are there any other engines that would be considered a direct swap? could i install a D16Y7 for instance? i know the ecu would have to be changed if i did that, anything else have to be changed? i'm not looking for performance here, just to get this car running cheaply again.
also if you have any sources for a good deal on any of these engines please let me know. thanks.
Old Jan 6, 2004 | 07:01 PM
xcchicx's Avatar
Default Re: engine swap question (sbacchus)
the d16y7 will bolt right in but you will have to change some sensors. you can use the p28 ecu but your check engine light will stay on cuz vtech is not there and i believe you will have to use the d16 dizzy. and b series bolts right in with b series motor mounts. good luck
Old Jan 7, 2004 | 04:20 PM
thad
Guest
Posts: n/a
good to see nu-Bs lookin out for nu-Bs, might i suggest you search for B and D series swap info.
Old Jan 7, 2004 | 07:11 PM
VTECVillain's Avatar
Default Re: engine swap question (xcchicx)
The D16Y7 can be a direct bolt in as long as you use the driver's side mount and bracket from your Z6. You can switch the Y7 intake manifold to the Z6 manifold and eliminate any sensor issues. If the head from the Z6 is good, then you can mate it to the Y7 block for a "mini-me" and reuse your P28 ECU. If not, you will want to get a 92-95 P06 DX/LX ECU to run the Y7.
Just check with salvage yards because the D16Y7 can be found cheap and are more than plentiful. I have 2 cars with Y7's in them right now: an 89 DX hatch and a 90 4wd wagon. They make great replacement motors.
Old Jan 7, 2004 | 07:22 PM
sbacchus's Avatar
Default Re: engine swap question (VTECVillain)
thanks for the replies all, they were helpful, trying to figure out how to get the money to pay for one of these engines now
Old Jan 7, 2004 | 08:47 PM
Indiana Jones's Avatar
Just go K series and call it a day!
Old Jan 7, 2004 | 09:17 PM
Turbogixxer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sbacchus &raquo;</TD></TR><TR><TD CLASS="quote">i'd like to get it running again as cheaply as possible. ...... are there any other engines that would be considered a direct swap? could i install a D16Y7 for instance?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA Gen2teg &raquo;</TD></TR><TR><TD CLASS="quote">Just go K series and call it a day!</TD></TR></TABLE>
Read, please
Old Jan 8, 2004 | 08:29 AM
RTE117's Avatar
Default Re: engine swap question (NA Gen2Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA Gen2Teg &raquo;</TD></TR><TR><TD CLASS="quote">Just go K series and call it a day!</TD></TR></TABLE>
hahaha.. would be nice.. dunno how fun that badboy would be putting in
Old Jan 8, 2004 | 09:38 AM
doublejz's Avatar
Default Re: engine swap question (IDriveAHonda)
if you decide to go y7 and you need a Z6 manifold i have one you can have for cheap
OliverV
Feb 10, 2009 02:03 PM
whiteknightef
Dec 6, 2005 06:32 PM
Thrillhouse
Apr 12, 2002 12:59 PM
