Engine stall if i pull the car?
Old May 24, 2004 | 01:44 PM
Bictorious's Avatar
Default Engine stall if i pull the car?
There seems to be something wrong with my Type R motor inthe CRX. The Idle is set at 1500 rpms, the reason i did that was because everytime i run my car and drop it back down to neutral, the rpms drop till its about to stall! What could be the problem? tps? ecu?
Old May 25, 2004 | 12:13 AM
Bictorious's Avatar
Default Re: Engine stall if i pull the car? (Bictorious)
anyone know?
Old May 25, 2004 | 08:41 AM
Greasemonkey's Avatar
My B18B does that too in my EK. But mine kind of jump and then it goes back to 1000 rpm..
* Are you running header out? When I first did my swap I was running header out and when I rev it, it would die because there was not enough back pressure.
uvamosk
Dec 7, 2011 05:49 PM
pmpm06
11
Jan 13, 2008 02:25 PM
crexer
Nov 24, 2007 07:16 PM
crexer
Nov 22, 2007 03:36 PM
