Engine Harness question
I had a GSR swap in a 88 hf, i pulled the motor along with the harness attached. I then put the motor with the hf harness into a 91 si. Now the car will not start, is it the harness or something else. The motor will turnover, getting fuel and spark but just will not start. Suggestions are appreciated. Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOOKUPS »</TD></TR><TR><TD CLASS="quote">just a rule of thumb use the harness out of the car that you are swaping.. same harness same car</TD></TR></TABLE>
right - you need Si harness - they are not interchangeable
v-tec maz
Jan 8, 2006 07:01 PM
