EF Guys?
Old Aug 24, 2004 | 02:23 PM
kshymkiw83's Avatar
Default EF Guys?
I am going to go LS/Vtec Turbo on a 89 Civic DX. I had some questions:
1. B18A or B18B? What is the diffrence or is the difrrence just in OBD-1 and OBD-2?
2. Should i get a first gen (OBD-0) B16 head or a OBD-1 B16 Head? Along with this what headgasket should i use?
3. ECU?....Hondata will work with OBD-1 but not OBD-0 correct? What about the Greddy E-manage?
4. Transmision.......Cable or Hydro clutch?
5. Pistons, Rods, rings......what brand should i use for a Turbo set-up. Also what compression ratio should i be shooting for?
6. Axles.... as well as shift linkage.
Well i guess that is all, this is pretty EF specific stuff, but anyone please chime in and help.
Old Aug 24, 2004 | 04:28 PM
MI KENT's Avatar
yo check out my buddies site for answers to all your questions. http://www.ef-honda.com sign up. post. be done with the wondering
Old Aug 25, 2004 | 06:42 PM
Mires's Avatar
Default Re: (MI KENT)
Yeah thats a great site. Lots of EF information.
Modified by Mires at 1:57 AM 8/26/2004
Old Aug 26, 2004 | 09:52 AM
smart monkey's Avatar
Default Re: EF Guys? (kshymkiw83)
B18a or B18B are all the same except the cams in the 90-91, those are weaker. also a B18a or early b's are high mileage by now but if rebuilding no matter
B16a heads are the same except the OBD1 models have a billet spray bar as opposed to cast on the first gens. better oil flow, but not a big deal
use the the ls headgasket if going ls vtec
hondata P28 is good or any obd1 ecu with hondata is fine, I heard you can use the hondata on obd0 pr3/9wo but one tuner i spoke to says there is a issue with the data logging for tuning , obd1 is better still from my experience
I like the hydro trans. newer and parts more available for rebuild. those cable trans are old now and all beat up
I like using wiseco gsr pistons or wiseco in general, je is fine. rods I use crower but eagle is affordable and work well
axles I like oem . no issues. as for linkage go hasport or mod a 90-93 teg one
Old Aug 26, 2004 | 01:16 PM
kshymkiw83's Avatar
Default Re: EF Guys? (smart monkey)
thanks man.
jakekenny
20
Jun 17, 2014 05:05 AM
boostedefhatch
27
Mar 8, 2009 02:27 PM
Grip
Feb 11, 2004 05:42 PM
enabi
Aug 23, 2002 06:23 AM
