EF b16 idle issue
Old Dec 28, 2014 | 07:02 AM
rspecturbo's Avatar
Default EF b16 idle issue
Have a b16a obdo with a pr3 ecu. I've replaced the tb with a new one and bypassed the fast idle. I have huge issues with the start up. Once I start it up I have loop idle and even dies out then I have to hold the gas till it can hold its self. Cleaned the ivac and still have issues...any ideas?
Old Dec 28, 2014 | 11:14 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: EF b16 idle issue
Did you check the FITV (fast idle thermo valve) or are you calling that the "fast idle" ??? If so, how did you "bypass" it ??? Also, make sure that the T/B gasket fits your throttle body... if it is too long and hangs off the bottom, you will have a leak that creates the "hunting" idle that you describe. Also, verify that the TPS voltage is set properly.
Old Jan 3, 2015 | 08:52 AM
rspecturbo's Avatar
The throttle body I bought for my car does not have it, simply just goes right on threw to the other hose, and i will take a look at my throttle body to see if thats the issue becuase i do know it wasnt the correct gasket for it. i honestly wish I was the original person who did the swap tons of issues with this sucker...
Iloveyourhonda92
Apr 11, 2015 07:46 PM
black bandit
Jan 14, 2008 04:26 AM
95dc2teg
Sep 11, 2007 05:49 PM
michael_antoi
Feb 22, 2006 03:36 AM
