Ecu help
Hello there I was wondering if I should use a p28 or p72. I have both and what is in the car now is the p28. I am putting a b16 into the car. What are the pros and cons on the two different ecus. Thanks
The p28 can run a p72 map and control the iab's without the knock board
http://www.rdtech-online.com P28 spec ecu running p72 map with iab control and necessary wiring.
Modified by 97_EJ6_Hatch at 7:16 AM 4/29/2007
MOVE OVER
Sep 6, 2007 08:59 AM
