ecu harnesses
I heard through the grape vine that there is a company out there that makes harnesses.
can anyone direct me? I need a P28 chassis to a P74/75 ecu harness for my swap.
Thanks for any leads.
Thanks for the replies guys...
But it's not what I'm looking for on the pro-speed site.
Both ecu's are obd I. I don't need that.
Basically, When i put this new ecu in my car, I don't want to sit there and wire/solder wires together from the harness of my car to the wire/ecu side that goes to the ecu from the engine.
I'm looking for something that will plug into the LS ecu (p74) but has the correct pin-outs for a 94 del sol (same as 92-95 civic si/ex) wireing.
any other suggestions?
Thanks
Thanks
Because the Vtec uses extra wires over and above what is there for the non-vtec motor. Without Vtec, the extra wires are just along for the ride. They don't do anything.
does anyone have a pint out for these ecus? or a site were i could find them? that would be a big help.
I jsut want to make sure i'm doing it right.
other friends have told me to just use the p28 with the b18b1. And that too sounds iffy to me....
Guest
Posts: n/a
Are you putting a LS into a delSol?
Was your original engine a D16 VTEC? and now you're installing a B18B?
If this is so, you don't need sh*t. Just plug in the ECU and use the LS engine harness and you're done. It's easy as pie. Anyone who tells you differently is trying to sell you something, or doesn't know what their talking about.
NOW, just to be clear, this goes for same year to same year.
I.e.
93-95 delSol to 94-95 Integra LS
96-97 delSol to 96-98 Integra LS
Get it?
OBD1 to OBD1
OBD2 to OBD2
Any other questions?
HTH
I.e.
Get it?
OBD1 to OBD1
OBD2 to OBD2
HTH
yup- 94 del sol Si chassis-
94 b18b1 motor is going in.
But then you mention engine harness...
see thats what i don't want to do. the wires that came with my motor, are, well- see for yourself...
thats the wad of poo poo that will go through the firewall.
wireing all that together is what im trying to avoid.
[Modified by delvtecsol, 3:21 PM 1/28/2002]
Is that an OBD 2 harness and computer? I can't really tell in the picture! No wait i must be trippin i guess the plugs wires are only stacked two high.
[Modified by JDMspecEG6, 11:33 PM 1/28/2002]
Use your Del Sol wiring harness, and extend a few wires here and there to reach the corresponding sensors. That'll be way easier than trying to put that cut harness back together.
That harness in the pic is an inside wiring harness, not an engine harness. Don't use that at all. Get a 94-95 Integra engine harness, attach to your engine, and your all set. You don't need to do anything. You could also use your Del Sol engine harness off your old motor, attach and then extend any sensor wires if necessary.
hawj_boi_1
May 30, 2006 05:54 PM
