ecu/harness question
Old Sep 28, 2005 | 12:11 PM
jadsi420's Avatar
Default ecu/harness question
swapping a jdm itr motor into a 99si. half of the wire harness won't plug into the jdm ecu that came with the motor. Is there a conversion for this. I need to use the jdm ecu so i don't have to add the extra solenoids. thanks in advance.
Old Sep 28, 2005 | 12:33 PM
jadsi420's Avatar
Default Re: ecu/harness question (jadsi420)
Ive been searching and it looks like i might need to get a wire conversion from obd2a to obd2b. Would this solve the problem? I just don't know which obd2 system the jdm ecu from the itr is using. any info would be appreciated.
Old Sep 28, 2005 | 02:58 PM
locash's Avatar
You'll need to use your stock 99 Si engine harness on the new motor, and an ecu adapter like this one..
http://locashracing.com/store/...id=46
Old Sep 28, 2005 | 05:08 PM
jadsi420's Avatar
Default Re: ecu/harness question (locash)
thanks for the info. i did figure it out though and ordered a conversion harness from boomslang.us for $139. i overnighted it and should get it tomorrow. i should be able to start the engine tomorrow.
sleeprteg
Feb 26, 2007 08:32 AM
Kirk@SyndromeAuto
Dec 13, 2006 05:24 PM
94IntegraLs04
Aug 10, 2005 09:13 PM
MINIMOKE1977
May 5, 2004 05:13 AM
