Which is easier top or bottom?
Old Sep 14, 2005 | 06:39 PM
redsled00's Avatar
Default Which is easier top or bottom?
What's easier when you swap an engine. Pulling the engine from the top or from the bottom and how about putting the other motor in;top or bottom?
Old Sep 14, 2005 | 06:42 PM
Jago's Avatar
Default Re: Which is easier top or bottom? (redsled00)
depends on what car your pulling it out of
Old Sep 14, 2005 | 06:57 PM
slomofo's Avatar
GDD Member
On civics/integras, I go bottom.
Prelude/Accord, Top.
MR2 - bottom.
Camry - Top
Trucks - Top
Geo Metro Type-R - Bottom
F-Body Camaro - Bottom
VW 1.8T - Bottom
VW Beetle - Bottom
Audi A6 - Top
Mercedes 560SEL - Top
Toyota 4Runner - Top
Nissan Sentra B13 - Bottom
Old school 80's integra - Top if you wanna remove battery tray, otherwise Bottom
NSX - Bottom
LS400 - Top
WRX - Top or bottom if you take out the suspension/tranmission at the same time.
What kind of car?
Old Sep 15, 2005 | 06:57 PM
redsled00's Avatar
Default Re: (slomofo)
I'm putting in a b16 in a civic. I was just wondering if I needed to get a cherry picker or if i'd be ok with doing it on the bottom. thanks for the replies though
Old Sep 15, 2005 | 08:31 PM
DavidR's Avatar
Default Re: (redsled00)
I've done 5-6 installs/pulls from EG Civics, but my last install was done from the bottom. I removed the crossmember/LCAS/steering rack and rolled the engine from the bottom on a furniture mover. Then, lowered the car down on the engine. It was so easy, I'll never do it another way.
Old Sep 15, 2005 | 09:48 PM
FlatBrokeHatch's Avatar
Default Re: (DavidR)
You'll have guys swearing that top is easier and guys that swear that bottom is easier. I've seen guys drop old motors out the bottom, then drop the new motor in the top. 3 swap here and I've always pulled it out the top. Good luck either way.
Old Sep 16, 2005 | 07:14 AM
jdm123's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redsled00 &raquo;</TD></TR><TR><TD CLASS="quote">I'm putting in a b16 in a civic. I was just wondering if I needed to get a cherry picker or if i'd be ok with doing it on the bottom. thanks for the replies though</TD></TR></TABLE>
it would be easier to go from the bottom, but you will still need a engine hoist.
Old Sep 16, 2005 | 08:31 AM
ben1818's Avatar
Default Re: (jdm123)
In the civic it really doesnt matter witch way it all depends on if you have something to lift the card and drop the engine or if you only have someting to lift the engine
Good luck
Old Sep 16, 2005 | 09:23 AM
jmayhew's Avatar
Default Re: (ben1818)
h22a4 went into my 92 VX from the top....& pretty easily.
Old Sep 16, 2005 | 09:57 AM
IHateJDM's Avatar
Default Re: (jmayhew)
^ I thought this thread was gonna be about something else...
Depends on what tools you have. Personally, I usually choose top.
Old Sep 16, 2005 | 03:29 PM
slomofo's Avatar
GDD Member
If I were doing it at home, i'd go for the top.
Old Sep 18, 2005 | 11:41 AM
d16vtecx's Avatar
Default Re: (FlatBrokeHatch)
done 5 swaps always from the top but have seen the bottom done a few times
its just personal preference
Simply.Smooth
Honda Civic (2001 - 2005)
Dec 10, 2015 04:57 PM
djnikko
Jun 4, 2010 05:06 PM
Mr_ET
Mar 3, 2010 06:24 AM
meagainsttheworld
Aug 18, 2006 09:11 PM
accordance73
May 13, 2003 11:44 PM
