Drivetrain weird Noise : Help
Old Oct 15, 2003 | 11:41 AM
hyperB16Turbo's Avatar
Default Drivetrain weird Noise : Help
Grinding noise when both tires goes on bumps. Feels like the shocks are bottoming out. I checked the shocks and its fine, axles are new also.
It doesn't do it when one wheel goes on the bump, both wheels have to be on the bump.
TIA
Old Oct 15, 2003 | 02:02 PM
poison's Avatar
Default Re: Drivetrain weird Noise : Help (HyperH22)
Hmm, do you have a front sway bar? Sounds like a bushing is ripped, or the damper is probably not assembled properly...
Was it working before and just happened or did you do any suspension modifying before then?
Old Oct 16, 2003 | 06:37 AM
Default Re: Drivetrain weird Noise : Help (poison)
I have the stock sway bars that came with the car.
It just happened.
Old Oct 16, 2003 | 02:40 PM
Bloodline's Avatar
I drove the car yesterday as well. It's weird. It will only make the noise if both wheels hit a bump at the same time. Like coming up onto the expansion joints of a bridge. The car has to be moving as well. If you get to people and just push down on the front of it repeatedly to make it bouce, it wont make the noise. Hopefully, well get a chance to take a look at it tomorrow or saturday.
jeff
Old Oct 17, 2003 | 09:29 AM
doublejz's Avatar
sounds to me that the axles could possibly be hitting. if it doesn't make the noise then obviously it has to be something in motion. cv joints ?
Old Oct 27, 2003 | 07:55 AM
Default Re: (doublejz)
I replaced both axles, shocks, and the problem still exist.
Somebody has to come across this problem..
Help....!!
Old Oct 27, 2003 | 08:12 AM
dc2h22's Avatar
What is your set up?
sohcFerio
Suspension & Brakes
11
Dec 10, 2011 02:50 AM
recon23
Aug 3, 2009 10:52 PM
JoeCb18
Jul 26, 2008 05:03 AM
HondaH22A
11
Sep 9, 2005 11:53 AM
distortedfuture
26
Feb 4, 2004 12:13 AM
