drivers side mount on evo h2b kit
Old Oct 15, 2010 | 04:48 PM
GSR_EJ's Avatar
Default drivers side mount on evo h2b kit
does the evo kit drivers side mount bracket fit my current 2 post mount(hasport) or do i need to buy the 3 post mount?
Old Oct 15, 2010 | 05:02 PM
BrowNKiD's Avatar
Default Re: drivers side mount on evo h2b kit
buy QSD!!!
Old Oct 16, 2010 | 05:35 PM
GSR_EJ's Avatar
im going evolution for hood clearence. im not trying to advertise.
Old Oct 17, 2010 | 05:43 PM
DSRxCandyh2bEG's Avatar
in order to use a evo kit, you have to use their engine bracket, the part that bolts to the block, and their motor mount, the part that bolts from the engine bracket to the chassis...
Old Oct 17, 2010 | 06:24 PM
GSR_EJ's Avatar
I know what a bracket and mount is. i was told hasports where ok to use, do they not work? i just wanna know if i use the hasport 3 bolt or 2 bolt mount with the evo kit. i currently have the 2 bolt mount in my eg.
Old Oct 18, 2010 | 02:22 AM
Its all proprietary... everything is part of the evo kit. So like I said, you have to use their bracket and mount...
The motor is repositioned so the hasport trans mount would not work, otherwise your engine and trans would sit crooked. For that reason, it would opt out the driver side mount as well...
Old Oct 18, 2010 | 03:41 PM
GSR_EJ's Avatar
Well i guess im just gonna go qsd, lol. Is my 2 bolt mount gonna fit the qsd kit? Ive seen posts that both qsd & evo have bad customer service and the kits take months to receive, is this true?
Old Oct 18, 2010 | 04:52 PM
The QSD Kit uses the 3 bolt DC2 style hasport kit. I believe all the mounts on your kit should be the same except the driver side... you do need the 3 bolt driver side hasport mount to make it work.
Some people have had a tough time getting a hold of them, others have had easier times. Just try and call them, leave them a message if you don't get someone on the phone. You can try PMing them as well.
Bserious: https://honda-tech.com/forums/members/bserious-999315886/
Old Oct 18, 2010 | 05:27 PM
black93octane's Avatar
YOu need all 3 evo h2b mounts because they are offset so that you have better clearance. You need to call evoindusa.com and tell them what you need. They used to sell the mounts seperate for 380. Very nice people to talk to.
existanzcivicb20
Apr 18, 2017 03:12 AM
93JDM_H22
Jul 1, 2010 12:04 AM
jaskuloski97sh
Jul 20, 2007 09:30 PM
w-fuck-ay
11
Aug 3, 2003 09:15 PM
Reddog
Jul 17, 2002 07:24 AM
