Do i need a gsr cat?
Old Jul 10, 2005 | 10:36 PM
Mugen112's Avatar
Default Do i need a gsr cat?
Im not sure but I think I need a gsr cat. Im swapping a b18c motor into my '93 ex coupe. I got the motor in, but it doesnt look like my stock cat will fit on to the gsr header. Do I have to get a gsr cat? Also, if i do get a gsr cat, will it bolt up to the rest of the stock civic exhaust? thanks.
Old Jul 11, 2005 | 12:23 PM
Mugen112's Avatar
anyone know?
Old Jul 11, 2005 | 02:21 PM
93b16CivicSi's Avatar
Default Re: (Mugen112)
i used the same cat from my sohc 93 si on my jdm b16.
Old Jul 12, 2005 | 12:33 AM
Mugen112's Avatar
hmm.. maybe its because this is a 1.8 liter and my stock motor was a 1.6 . Anyone know??
Old Jul 12, 2005 | 07:14 AM
gents97civ's Avatar
https://honda-tech.com/zerothread?id=1289772
Old Jul 12, 2005 | 07:15 AM
gents97civ's Avatar
if you use this header and cat it will bolt right up. This is what I had on my car. I have a b18c. The header is longer, the cat is just stock usdm. I will sell you just the bottom of the header if thats all you want for cheap.
Old Jul 12, 2005 | 08:29 PM
neeks's Avatar
Default Re: Do i need a gsr cat? (Mugen112)
i have the same year civic as you except mine is a hatchback and ill tell you FOR SURE that you need a gsr cat converter..(the diameter is different for civics than integras)
not just that but you need a gsr exhaust (top and bottom piece) b-pipe and exhaust as well..dont worry itll bolt right up and the hooks match up...
im having a little bit of trouble fitting my exhaust tho...ill figure that out later...
also if youre trying to get the car ref'd you should get an obd2 cat converter w/o2 sensor...
good luck
Old Jul 12, 2005 | 09:01 PM
Mugen112's Avatar
WHAT?!? i need a whole new header/cat/exhaust just because the cat ont fit onto the header?? I think if i just get a gsr cat it will bolt up just fine wont it?
Old Jul 12, 2005 | 09:47 PM
HavokB18's Avatar
You dont need all new ****....
My setup was stock GSR header with a GSR high flow cat then i had an exhaust shop cut my stock exhasut flange off and weld up one that would bolt to the high flow cat cost me 50$
Anyways the cat cost me somewhere between 70-100 i cant remeber but there were two version and i got the nice one lol. I still have it and it only had like 5k on it if you want it i could find it and we could work out a price.
Old Jul 13, 2005 | 09:58 PM
Mugen112's Avatar
You have pm HavokB18.
Old Jul 13, 2005 | 10:26 PM
HavokB18's Avatar
didnt get it?
Old Jul 14, 2005 | 04:48 AM
StorminMatt's Avatar
Default Re: (HavokB18)
Just go to a muffler shop and get a custom flanged cat made that will correctly bolt to your header and exhaust.
finest_GSR
Mar 5, 2006 06:07 PM
Mugen112
Jul 21, 2005 09:47 PM
Easyslider01
Apr 3, 2005 06:59 PM
urgonnalearn2
Mar 31, 2004 03:57 PM
