Which distributor can i use?
Old Jan 15, 2003 | 11:51 AM
Soled Out's Avatar
Default Which distributor can i use?
The shaft on my distributor is shot, so i need a new distrbutor.
What distributor will work on a OBD-1 B16aII?
Old Jan 15, 2003 | 02:40 PM
Jeff C's Avatar
Default Re: Which distributor can i use? (Gray EG on Jack Stands)
92-95 GSR, 94-95 DOHC VTEC Delsol or 92-95 LS (with modification). Also (if you are really desparate), it is my understanding that the only diff between the obd1 and obd2 dist's is the plug (the actual internals and mount are identical) so you could also use an obd2 dist, but you will have to repin the plug to match your obd1 harness or swap the internals.
Old Jan 15, 2003 | 03:50 PM
Soled Out's Avatar
Default Re: Which distributor can i use? (Jeff C)
Thanx JeffC
I called Osaka and they said they'd send me one tommorrow, so we'll see if they can earn some of my respect back
[Modified by Gray EG on Jack Stands, 7:50 PM 1/15/2003]
skoodles2k6
Nov 30, 2007 06:48 PM
efdrifter
Nov 8, 2007 09:14 AM
nikkarocky
Apr 10, 2007 12:54 PM
specie
Jun 14, 2004 06:32 PM
h22acivic4u
Jul 8, 2003 10:18 PM
