Dist/Ecu question
Old Sep 15, 2002 | 03:05 PM
cstgrd's Avatar
Default Dist/Ecu question
CAN I USE A DIST. OFF A SINGLE CAM 1.5L ON A B16A1? AND IS THE B16A1 AN OBD 0 OR AN OBD 1 CAUSE A SHOP TOLD ME ITS AN OBD 0 IM NOT SURE IF HE IS JUST TRYING TO GET MONEY OUT OF ME THANKS
Old Sep 16, 2002 | 08:45 AM
VTECVillain's Avatar
Default Re: Dist/Ecu question (cstgrd)
The D series distributors won't fit B motors. Most B16A motors are non-OBD although there was a rare version of it in the 92-93 JDM Integra XSi that is grey plug OBDI and still a B16A, not A2. The only thing you can do is use the non-OBD SiR distributor on the non-OBD B16A or a 90-91 Integra LS will work. The LS requires hacking a leg off to make it mount properly and it limits your range of timing adjustment but it does work.
crexer
Aug 25, 2002 10:24 PM
ef civic
May 14, 2002 02:53 PM
boosted hybrid
Feb 7, 2002 05:16 PM
VTECVillain
Dec 21, 2001 09:23 AM
