Difference between 94-97 98-01 B18c1
Old Aug 6, 2002 | 02:46 PM
HybridHatchC1's Avatar
Default Difference between 94-97 98-01 B18c1
I was wondering if you can tell the difference between the two engine from the visable piont of view, like if you looking at the engine can you tell a difference, are the markings on the head different?
Old Aug 6, 2002 | 05:05 PM
IlikeTODA's Avatar
Default Re: Difference between 94-97 98-01 B18c1 (Civ-JDM)
94-95 are OBD1 and 96-01 are OBD2
It depends on what all is there. The injectors on the OBD1 have little metal clips where as the OBD2 are just normal pugs. You could run the numbers of course. I can't remember what else would stand out to me. Hope that helps some.
Thanks, J
[Modified by IlikeTODA, 2:10 PM 8/7/2002]
Old Aug 6, 2002 | 05:37 PM
R_yd's Avatar
Default Re: Difference between 94-97 98-01 B18c1 (IlikeTODA)
94-97 are OBD1 and 98-01 are OBD2
WRONG! obd2 starts from 1996
Old Aug 6, 2002 | 05:52 PM
98DC2-ITR's Avatar
Default Re: Difference between 94-97 98-01 B18c1 (Rspool)
Most 96 up OBDII GSR's had a VIN # on the block where 94-95 didn't. Also look for a crank angle sensor on the 96+ engine. It can be identified by a black wire loom running down the back of the block behind the timing belt cover. It goes into the cover behind the harmonic balancer. I hope that helps....
Old Aug 7, 2002 | 07:12 AM
Default Re: Difference between 94-97 98-01 B18c1 (4thapack)
ok thanks guys, i am going to pick up my gsr swap for project hatch.
Old Aug 7, 2002 | 08:13 AM
Kalokohan's Avatar
New User
94-95 = OBDI
96-Up = OBD II
94-95 had only 1 O2 sensor, 96-up has an O2 sensor on the header and the cat.
94-95 IAB's required a negative signal to trigger as opposed to OBDII which requires a positive 12V signal. That's all I can think of right now.
Old Aug 7, 2002 | 11:10 AM
IlikeTODA's Avatar
Sorry for the bad info. I had a brain fart.
Thanks, J
CivicTT
Jul 12, 2010 01:29 PM
ferio_boy
Mar 19, 2008 10:47 AM
BIG RICH
Jul 3, 2006 09:31 AM
JMcDB18C
May 22, 2005 09:07 PM
IEATLINT
Aug 10, 2003 09:08 PM
