DA with OBD2 ITR Swap. Need help with problem!!!
Old Jan 3, 2008 | 03:23 PM
Captain JDM's Avatar
From: Tucking wires like crrraaazzy up and down the east coast!!
Default DA with OBD2 ITR Swap. Need help with problem!!!
Ok, so the DA has an OBD2 ITR swap in it and the car runs pretty good. but for some reason at 1500 rpm's(if held there) it jumps up and down, similar to 2 step. i changed out the map sensor thinking it might be that but no luck. any body please chime in! not sure what the problem would be.
Old Jan 4, 2008 | 11:02 AM
anybody?!!
Old Jan 4, 2008 | 11:28 AM
lowntegra's Avatar
Default Re: (Captain JDM)
any codes? my civic with b20 swap does that occasionally too. i've checked everything in the ignition system, IACV,TPS, two different throttle bodies...no codes or anything...hmm..
Old Jan 4, 2008 | 12:06 PM
tnxx's Avatar
it's your distributor wiring. make sure they are correct from obd0 to obd2. that happened to me before.
Old Jan 5, 2008 | 06:26 AM
it doesnt have any codes. good call on the distributor ill check that and get back at you.
elmalouno
Jul 3, 2011 09:00 AM
kaktusr
Jul 29, 2008 10:42 AM
Captain JDM
Jan 4, 2008 11:01 AM
Nameless RB26
Oct 4, 2004 03:47 PM
