ctr pistons on a gsr block???
ive heard 11:1 is good
runs great on 92, but when you get to 11.5 up to 12+ you got to start worrying about detination and idle, not to mention vavle lift
[Modified by GSRdreaming, 6:51 AM 6/10/2001]
ITR runs a 10.9:1 does it not?(might be 10.6:1*shrug*) what does the CTR run? and 11:1 is not to bad (well gas sucks) seems to run fine to me. again why would the CTR be to much?
That is totally correct-your compression ratio would be too high and you have to remember that the GSR combustion chamber has a clover leaf design.
ok ok so that is the difference, the shape and design is different placeing the vavle reliefs in different spots cuz the heads are shaped different. hmmm.... i didnt want to pretend to know, thats why i asked.
hell, i just ordered what i needed, not knowing it could be different for the B16
I run ctr's in a j spec b18c all day long on 92 octane. I have no problems. I am worried about valve clearance w after market cams though! or even cam gears.
ctr pistons in a gsr head is 11.6 cr. You can have up to 11.8 to 1 on pump gas. By the way the new celica is 11.5 to 1.
[Modified by stretracr, 7:45 AM 6/21/2001]
JDM Lyfestyle
Jan 31, 2009 05:51 PM
WhoDoYouThink
Oct 4, 2005 01:02 AM
duRritztiNy
35
May 16, 2003 10:36 PM
