ctr crank pully
Here's how you figure it out.
Get some string and wrap it around the two pulleys. Remove and measure the string. Multiply inches by 25 to get millimeters. Pivot the alternator forward/backward to find minimum and maximum belt sizes.
The alternator belt is a 4 groove belt. Belt size will begin with "4pk".
For example my b16 w/ctr pulley uses a 4pk735 alternator belt.
Modified by eda6 at 9:42 PM 3/22/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">I believe it's a 295mm belt.</TD></TR></TABLE>IF im not mistaken..that is the right belt size. I'm glad I don't have that pulley on my car anymore. I believe it was the culprit to my bearings failure and my crank to "walk".
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NVturbo »</TD></TR><TR><TD CLASS="quote">IF im not mistaken..that is the right belt size. I'm glad I don't have that pulley on my car anymore. I believe it was the culprit to my bearings failure and my crank to "walk".
Crank walk would be due to worn out thrust washers. Also happens when you put them in backwards (they wear out VERY quickly when in backwards)
</TD></TR></TABLE>Crank walk would be due to worn out thrust washers. Also happens when you put them in backwards (they wear out VERY quickly when in backwards)
I can't picture using a 295mm belt since my b16 uses a 735mm belt. Did you mean 925mm?
Your answer is in the third post. Please post the belt size after you've installed it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg »</TD></TR><TR><TD CLASS="quote">
Crank walk would be due to worn out thrust washers. Also happens when you put them in backwards (they wear out VERY quickly when in backwards)</TD></TR></TABLE>NO..they were not installed backwards. They were not "replaced" when I installed pistons and rods..the first time. Damn..damn..damn!!
98ej8coupe
Mar 17, 2008 11:35 AM
fbpem1
Jan 3, 2006 12:05 PM
MattD@Stoptech
Jul 30, 2003 09:36 AM
