crx h22 code 22 need help please
Old Jan 10, 2008 | 06:30 PM
rexthermal's Avatar
Default crx h22 code 22 need help please
sup i got a code 22 from my h22, crx car is converted to obd1, here is what happens, i would hit vtec maybe for half a second in 1st or second and it wont throw code but if i hit it in 3rd and stay in it engine light will come on directly i searrched and searched and i tried everything i read but no solution any help would greatly be appreciated
i have cleaned vtec solenoid 3x
changed oil psi switch
changed vtec solenoid
oil pump is good gauge reads fine oil psi
grounded the solenoid
grounded the oil psi switch
made sure all wires are pinned right in ecu
i dont know what else to do please help
Old Jan 10, 2008 | 08:02 PM
ESP.net's Avatar
Default Re: crx h22 code 22 need help please (rexthermal)
code 22 is vtec pressure valve
changin that should of fixed the code for a healthy one
Old Jan 15, 2008 | 05:50 PM
si vtec ftw's Avatar
Default Re: crx h22 code 22 need help please (ESP.net)
splice your pressure switch to your solenoid wire and then disconnect the pressure switch plug
most jdm motors dont have this and this is how it is done
it wont throw a check engine code and it will go into high cam.
the switch is really pointless because it makes sure there is enough oil to go into vtec but it uses oil pressure to go into high cam anyways so it cant go if there isnt enough pressure so its useless really.
but thats a good way to fix it. i did the same thing last weekend
no problems at all.
Old Jan 16, 2008 | 09:57 AM
MoonScryer's Avatar
Do what the above said, but I wired one into mine even though it was a JDM piece w/o one. I'd rather have the safety measure in case the oil pressure is low. I am paranoid with my cars, and a maintenance *****, but I love having it there.
Old Jan 20, 2008 | 06:29 PM
rexthermal's Avatar
thanks guys i will try tommorow morning if that doesnt work only thing left to do is take harness out and try another one????
Old Jan 22, 2008 | 04:07 AM
Default Re: (rexthermal)
been there.
could be your computer
if its an old computer it could just be bad
Old Jan 22, 2008 | 05:24 AM
rexthermal's Avatar
ive tried 3 different computers 2 p28's and one p72
Old Jan 22, 2008 | 05:01 PM
well just splice those wires.
should clear the problem up
as i said its a useless sensor
Old Jan 22, 2008 | 05:39 PM
miguel91911's Avatar
I had trouble with it one time and it turned out to be that the wires for the oil pressure switch were reversed. it fixed it for me. or like they said maybe the sensor it self is bad
Old Jan 22, 2008 | 07:04 PM
Default Re: (miguel91911)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miguel91911 &raquo;</TD></TR><TR><TD CLASS="quote">I had trouble with it one time and it turned out to be that the wires for the oil pressure switch were reversed. it fixed it for me. or like they said maybe the sensor it self is bad</TD></TR></TABLE>
dont waste money on the sensor.
get rid of it.
theres a black wire that is the ground and the other (idk what color) that is the signal wire.
splice it into your vtec solenoid wire, then unplug the pressure sensor plug and leave it hangin or remove it completly.
badda bing, pressure switch problem solved.
if the issue is still there, then idk what the problem is.
Old Jan 24, 2008 | 09:53 PM
rexthermal's Avatar
will let u know as soon as i try it tommorow
Old Apr 6, 2008 | 10:19 PM
rexthermal's Avatar
ttt still having trouble guyz
preludefien
Feb 11, 2007 10:43 AM
cioli
12
Feb 26, 2006 08:31 AM
hondacurab16
Sep 21, 2005 11:00 PM
drudy
Aug 7, 2005 05:59 AM
mister2racer
10
Jul 1, 2005 08:14 PM
