Is the crank trigger sensor necessary
Old Apr 5, 2004 | 11:22 PM
mchuang's Avatar
Default Is the crank trigger sensor necessary
Well I was hoping to find out if the crank trigger sensor is needed. I have a 2000 si with in which I just tped it on track
Old Apr 6, 2004 | 05:56 AM
ek99's Avatar
Default Re: Is the crank trigger sensor necessary (mchuang)
Crank fluctuation sensor? If you’re running the 2000si ecu then it is necessary.
CHAZegHATCH
Jul 20, 2006 06:33 PM
