couple problems after swap??
Old Nov 30, 2007 | 03:10 AM
Dackonn's Avatar
Default couple problems after swap??
swapped an OBD2 b18b into my 97 hatch, running an OBD1 b18b ecu with a jumper harness.
I have a low idle - and the intake sounds like its going to suck in every last drop of air on the planet ...the car also drops to abour 100 or 200rpms when I let off the gas and put it in neutral, then quickly jumps back up to about 500rpm (where it has been idling at) I have cleaned the IACV and still same problem, I am thinking that there is a vacuum leak somewhere due to the obnoxious noise the intake is making at idle??
#2 - My headlights and gauge cluster get brighter when I give the car gas it happens at about 3k rpms, and then they dim back down when I let off or brake etc ... could this be because of the low idle? the alternator and battery have been checked and they were both in great working condition .... bad ground somewhere? any suggestions?
thanks in advance
Old Nov 30, 2007 | 07:32 AM
JasonST's Avatar
Default Re: couple problems after swap?? (Dackonn)
Sounds like u eather need to convert ur engine to obd1, or get an obd2 ecu for ur obd2 engine. Any cels (check engine lights)?
Old Nov 30, 2007 | 07:48 AM
Dackonn's Avatar
Default Re: couple problems after swap?? (JasonST)
No CEL's, some people said the alternator could cause both problems, but I have had it checked and it was in good working condition as well as the battery ...
Old Dec 7, 2007 | 09:06 AM
Dackonn's Avatar
bump for some answers - I will be replacing the alternator this weekend to fix the headlight problem, regardless of the local shop telling me its ok, I have done everything I can and it isnt fixing anything (checked all grounds etc ...)
as for the idle issue, can a bad 02 sensor cause the problem? Im gonna look into it
Old Dec 9, 2007 | 05:10 PM
boosted_dc2's Avatar
why dont you just turn up the idle adjustment screw?
Landon
Old Dec 13, 2007 | 12:55 PM
Dackonn's Avatar
Default Re: couple problems after swap?? (boosted_dc2)
the idle adjustment screw is up, it didnt fix anything, I tried turning it up with the IACV unplugged like it says to and it still doesnt fix anything.
if the car stalls when the IACV is unplugged does that mean the IACV is bad altogether?
zcoffey
Jan 28, 2011 05:38 AM
Sprocksilvia
14
Jun 23, 2010 09:59 AM
soodominican
Jan 17, 2009 01:25 PM
soodominican
Jan 16, 2009 09:32 AM
StinkyTofu
Apr 6, 2003 09:31 AM
