compression with 91 octane
Old Feb 19, 2003 | 11:10 AM
TypeR0wnz
Guest
Posts: n/a
Default compression with 91 octane
this guy from import builders told me i dont need to sleeve when running 12.8 compression as long as i run race fuel to not detonate. i want to run 91 octane so he goes u can do that on 12.5 but i dont want o risk it so im gonna do about 12.1 with 91 how does that sound to you guys. also does anyone of u know if a company makes 2 layer head gaskets for a b20 block
Old Feb 19, 2003 | 11:15 AM
sgT's Avatar
sgT
Default Re: compression with 91 octane (TypeR0wnz)
you only have to sleeve for one of 2 things:
1. you exceed the bore that the stock sleeves can support
2. you exceed the HP that the stock sleeves can withstand
Old Feb 19, 2003 | 11:55 AM
Hooch'n's Avatar
Default Re: compression with 91 octane (sgT)
What is wrong with 93 octane? Or are you westcoast?
Sunoco has 94
Old Feb 19, 2003 | 02:38 PM
AK94GSR's Avatar
Default Re: compression with 91 octane (Hooch at 8400-RPM)
I always wondering how much compression i could run with 91 octane
does anyone have a scale or something to use as guide lines
Old Feb 19, 2003 | 06:09 PM
NightHawkC5's Avatar
Default Re: compression with 91 octane (AK94GSR)
i only have every minute access to 91 here in LA
Old Feb 20, 2003 | 05:11 AM
VTECVillain's Avatar
Couldn't have said it better
Old Feb 20, 2003 | 01:28 PM
Triple T's Avatar
Default Re: compression with 91 octane (VTECVillain)
Yeah out in cali we only have 91 octane, it sucks. Im going to keep my compression below 12 so it should be all good.
Old Feb 20, 2003 | 07:02 PM
TedR719's Avatar
Default Re: compression with 91 octane (triplet)
12:1 should be still safe on 91 octane.
I beleive the Celica GTS run a 11:5:1 c/r so 12:1 shouldn't be pushing it that much on 91
2k.civic.si
28
Jan 4, 2011 02:48 AM
blaak-crx
Sep 12, 2009 01:38 PM
P12 EG6
Sep 14, 2007 10:24 AM
Terrible One
14
May 10, 2005 09:29 AM
bpowa
Jul 18, 2004 07:28 PM
