Codes PO136 & PO138
Old Feb 13, 2004 | 02:39 PM
aaronblake9898's Avatar
Default Codes PO136 & PO138
Im trying to install a header on my 98 dx......but the header only has one o2 sensor bung on it......and no cat...........
Do i need an o2 simulator for the 2nd o2 sensor? If so, How does the simulator work? Would I have to even hook up the 2nd o2 sensor? Or, do I just hook the 2nd sensor's wires to the simulator?
Any HELP IS GREATLY APPRECIATED Thank You
Old Feb 13, 2004 | 03:52 PM
aaronblake98's Avatar
Default Re: Codes PO136 & PO138 (aaronblake9898)
How would you install the o2 simulator?
Old Feb 13, 2004 | 04:43 PM
Default Re: Codes PO136 & PO138 (aaronblake98)
bump
Old Feb 14, 2004 | 04:20 AM
VTECVillain's Avatar
You need to have a second O2 bung (I said bung ) put in the header or exhaust so that you can use your secondary O2.
Old Feb 15, 2004 | 09:42 AM
bump
Old Feb 15, 2004 | 12:03 PM
bump
jakscivic
Jun 10, 2006 01:13 AM
redpeppers
28
Sep 24, 2005 06:17 PM
aaronblake98
Feb 15, 2004 04:20 PM
aaronblake9898
Feb 13, 2004 03:55 PM
shadowstylz
13
Sep 15, 2003 10:33 PM
